Old 10-06-2013, 07:53 PM   #1
thatbryanguy
Drives: Yaris 3dr hatch
The map I'm using is the Rich map in the downloads section on Microimage. I haven't modified anything on it but figured I could use that rough tune to get me around until this next weekend or so when I get it on the dyno (little bday present from the wife!) so if anyone wants to look at that map and see if something is at all not the best for it the tune may end up solving everything. But I'll try to zero things out and see its effects if any.
thatbryanguy is offline   Reply With Quote
Old 10-07-2013, 05:25 AM   #2
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
.032 to .029.
I would go as low as .022
-Derrick-
Old 10-07-2013, 03:06 PM   #3
thatbryanguy
.032 to .029.
I'm not sure I'm going to mess with the gap anymore because I'm 90% sure it has to do with the FIC itself just because when the FIC is bypassed the car doesn't misfire at all. So I figured as long as the car is getting the signal to spark, it does and doesn't have a problem igniting the mixture without the FIC.
Old 10-07-2013, 03:18 PM   #4
ilikerice
ilikerice's Avatar
I hear ya. And you're probably right. I was just suggesting what gap I set mine. My crx had issues with loosing power at full boost. Is wasn't at bad when I went .033 and eliminated the issue completely at .022.
I am not saying this is the problem with your car. I am just adding my experience and what I set my gap when I was boosted.
-Derrick-
Old 10-07-2013, 08:46 PM   #5
thatbryanguy
@blown_xa, I do have a lightweight flywheel but you can hear and feel when it misfires so I don't think its a false code unless it's just idling rough for some other reason and the misfire code is just a coincidence
@ilikerice, no I get ya, that's why I did try closing the gap a bit but it just seems more like the problem is from another area. I also don't have any problems with misfiring when I'm giving it gas or hitting boost, it's only when I let go of the gas and idle or put it in neutral that you hear and feel it misfiring.
Old 10-07-2013, 10:22 PM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Try zero's yet in the lower RPM range yet? Sounds like its too rich at idle
Old 10-08-2013, 01:57 PM   #7
thatbryanguy
Haven't gotten to a PC yet but that is definitely one of my first things I'll try then I'll try all the different firmwares.
My brother is helping me put together a junk PC tower tonight with a bunch of his random spare parts to use. I'll post with the results of the change as soon as I get that all done.
Old 10-17-2013, 09:11 PM   #8
thatbryanguy
I finally got an old laptop to use to change my cal file on my FIC. So when I go to modify the fuel map on the cal file, what boxes should I make 0 for the lower rpms? I'm completely unfamiliar with how this works.
The car runs fines with a completely zero'ed out map (the base cal file) so I just need to know how exactly the FIC picks what boxes at idle. I see the rpms across the top but on the left it says psi so I'm not sure what to change.
Old 10-25-2013, 11:50 AM   #9
thatbryanguy
Update: Put in zeros for the boxes the FIC uses for idle and it helped a little it seemed with the roughness but it still stalls out at idle.
Old 08-14-2015, 09:22 PM   #10
Bluevitz-rs
Bump for reference....
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 04:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
AEM FIC to replace CamCon cc101 ?? vten Forced Induction Forum 26 08-04-2012 08:38 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
