Returning to Toyota
Drives: 2013 L 3dr MT Join Date: Mar 2013
As I understand the first oil added to the engine when brand new is designed to aid in breaking in the engine. Changing the oil early is not going to help the break-in process. It is also a huge waste changing oil more often than the maintenance is scheduled for, unless subjected to harsh conditions. Today's oils in modern engines can work effectively for much longer then the maintenance schedule calls for, but period samples must be tested by a lab to confirm that it is still good, so most of us do the normal change anyway at 5K miles.
| Maint Required light blinking after startup | brg88tx | DIY / Maintenance / Service | 20 | 10-22-2016 08:56 PM |
| How many more miles can you drive when the maintenance required light starts flashing | dante2086 | DIY / Maintenance / Service | 3 | 12-14-2010 07:24 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
| test fit 06-07 Yaris 4 door fog light | winson | California | 15 | 01-13-2009 08:25 PM |
