Old 04-11-2013, 10:24 PM   #1
If it only does it on start-up then it is likely that the belt is not tight enough.
Old 04-12-2013, 03:01 PM   #2
jcboy
Drives: Sedan 07
This, or it is too tight. if it's just about tight enough, try running a candle (literally) while it is spinning. the candlewax should be eaten away and it will silence the noise for a good year or so.
Old 04-12-2013, 05:01 PM   #3
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Had this same problem when replacing the belt. You have a lose drive belt PRY BAR it tight.Don't go to the mechanic for something you can do yourself, free of charge and in less than 5 minutes.They will suck everyone cent out of you those garages!
squealing noise at start up maui DIY / Maintenance / Service 13 09-22-2016 01:00 PM
Brakes Squealing! cmkennedy New England 1 10-30-2011 06:08 PM
Loud hamster wheel squeal noise - help Darwin84020 DIY / Maintenance / Service 7 03-14-2011 07:52 AM
Very loud noise from the engine Stiv DIY / Maintenance / Service 27 10-27-2009 10:09 AM
Loud scratching noise dngz General Yaris / Vitz Discussion 3 09-11-2006 10:56 PM
