Old 04-11-2013, 10:48 PM   #1
robkay
Drives: Hatch
Originally Posted by thepartsmancometh View Post
buy toyota red and dilute it. its cheaper, and essentially the same as toyota pink. Our toyota technical rep said its basically the same antifreeze without dilution.
Old thread I know, but still relevant. As my coolant is down a little I went over to the local dealer this afternoon to buy a gallon of red. He asked about my car and I told him it was an '07 Yaris. He said he thought the pink was spec'd for it and checked his book and confirmed. I told him I thought the pink was just diluted red. He went and got a gallon of each and showed me in the Contents list how there is a little difference in the composition between the two and they are spec'd for different model year ranges of vehicles.
Each component in the product has a name and number (even the water in the pink). They were the same in both, except for two components, I believe an acid and some chemical. Interestingly, one of the components had the same number on both products, but the name was different. The second component had a completely different name and number on each jug. He even walked out to the shop to ask a tech whether he knew if the pink and red were exactly the same thing, but he said he didn't know.
So, while the pink and red are similar and compatible it would appear that they are not quite exactly the same thing. Will either one cool your engine? Sure. Will using red in your Yaris, or mixing the two, cause engine damage? Doesn't sound like it, at least not in the short term. But, the pink "Super Long Life" product might be formulated to be nicer to engines it's spec'd for over a longer period of time than the red.
OTOH, the two chemical differences between red and pink as stated on the jugs might just be marketing mumbo jumbo BS to get people who bought cheaper cars to spend more money on parts.
Much as I was looking forward to saving money by buying the red ($31.84/gal which would make 2 gals when diluted), I caved and spent $21.81 to get a gal of the pink as it is spec'd for my car. sigh......
robkay is offline   Reply With Quote
Old 04-12-2013, 10:16 AM   #2
esse10
Drives: 2009 yaris 2 door
low coolant
If it was just a little low on coolant you could have just add some distilled water and call it good-to-go for now. If the problem comes back then deal with that. The coolant does not have to be mixed exactly 50/50 you can get away with running 60/40 with no issues. good luck folks
Old 04-22-2013, 04:30 AM   #3
nookandcrannycar
Perhaps I am being naive and paranoid, but with my OEM water pump still in place (and (frugal frugal frugal ) never doing a flush), when I did need to add some coolant (within the last 50k miles I think) I caved and bought the pink stuff.
Coolant Service N9QGS DIY / Maintenance / Service 31 11-27-2012 06:55 AM
Alternatives to Toyota "pink" super long life coolant Camberix DIY / Maintenance / Service 10 03-30-2011 11:42 AM
coolant reservoir? toad DIY / Maintenance / Service 10 11-02-2010 11:02 AM
Check your coolant bottle UTVitz DIY / Maintenance / Service 13 12-16-2009 09:13 PM
