Old 04-13-2013, 12:57 PM   #8
lamadoo
Drives: 2007 Yaris 3door white
Hi guys i just changed my brake fluid, i tried using the pump gun but it was getting so many bubbles and was tickling it down (cheapest gun on ebay i got...). I then just let it bleed but then the sun was going down so i used the other method of stepping on the breaks and using a tube with a bottle and some fluid inside to stop the air going out.
I finished the sequence in the correct order, but i had some fluid remaining so i decided to do the back and the driver back again...clear pure fluid. I then stopped and being the idiot i am didn't proceed to double checking the front and the front passenger. So i messed up the sequence when it was completed already... any problems?
It all came out clear bubbleless fluid but now my brake pads feel spongy, is that okay? will a little air hurt the brake fluids system? Thanks guys
lamadoo is offline   Reply With Quote
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Brake fluid change JonS DIY / Maintenance / Service 3 07-12-2012 12:48 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-26-2012 11:48 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
