Old 04-13-2013, 01:10 PM   #9
YarisSedan
Drives: 08 Yaris Sedan
Originally Posted by lamadoo View Post
Hi guys i just changed my brake fluid, i tried using the pump gun but it was getting so many bubbles and was tickling it down (cheapest gun on ebay i got...). I then just let it bleed but then the sun was going down so i used the other method of stepping on the breaks and using a tube with a bottle and some fluid inside to stop the air going out.
I finished the sequence in the correct order, but i had some fluid remaining so i decided to do the back and the driver back again...clear pure fluid. I then stopped and being the idiot i am didn't proceed to double checking the front and the front passenger. So i messed up the sequence when it was completed already... any problems?
It all came out clear bubbleless fluid but now my brake pads feel spongy, is that okay? will a little air hurt the brake fluids system? Thanks guys
Air wont hurt your system but it is going to greatly effect your braking. Just go with the simple gravity bleed that way there is no chance of messing anything up. Open each bleeder screw one at a time. If you dont have time just do the fronts that will get out most of the air for the time being in a short time to make it safe and then start over from the left rear when you have time.
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 08:50 AM
Did you know a different brand of brake fluid will change performance? UberSilver DIY / Maintenance / Service 5 03-05-2013 12:42 PM
Brake fluid change JonS DIY / Maintenance / Service 3 07-12-2012 12:48 PM
Should I change my brake fluid? lh59 DIY / Maintenance / Service 4 06-26-2012 11:48 PM
Brake lines/brake fluid change out jstantherprsn DIY / Maintenance / Service 3 11-02-2010 11:53 AM
