![]() ![]() Drives: 2009 Yaris Join Date: Oct 2010
Scott,
I travel about 125 miles a day and my plan is to drain it again in about 3-4 weeks, drop the pan, change the filter and refill. Upon reinstallation of the pan, should I use any silicone on the block/pan, or put in on dry? is there a pattern to tighten the bolts and what is the torque specs? Thanks. Richard |
#2 | |
Scott,
Man you're right only 69lbs, that's not very much. The wix filter I am looking at has a gasket with it. Do you recomend the OEM gasket only? Thanks for the help. Richard |
#4 | |
The Wix filter/gasket should be fine.
Scott,
Gotcha 6 ft-lbs, thanks again. I will let you know how it goes. Take care. Richard |
![]() Drives: 2007 Yaris HB Bayou Blue Join Date: Jul 2007
Auto Transmission Drain & Refill 07 Yaris HB
Hi CTScott, do you or any of the forum members know what the torque spec is for the transmission drain plug? I read on another thread that a member tightened the drain plug to 35 lb-ft but that seems excessive. Thanks.
| 2012 Nissan Versa | Kal-El | Off-topic / Other Cars / Everything else Discussions | 22 | 06-15-2012 04:48 PM |
| auto transmission fluid change | bribri | DIY / Maintenance / Service | 4 | 01-01-2012 10:39 AM |
| Super Amazing Oil Change DIY | id3379 | DIY / Maintenance / Service | 34 | 11-28-2008 01:20 PM |
