Old 04-13-2013, 11:02 PM   #24
Originally Posted by potorap View Post
Scott,
I travel about 125 miles a day and my plan is to drain it again in about 3-4 weeks, drop the pan, change the filter and refill. Upon reinstallation of the pan, should I use any silicone on the block/pan, or put in on dry? is there a pattern to tighten the bolts and what is the torque specs? Thanks.
Richard
There's an OEM gasket for the pan, so get a new one along with the filter, and no silicone is required. The torque on the pan nuts is only 69 in-lb, which is a whole lot less than you would expect. There isn't a specific pattern for tightening the 19 bolts,
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
auto transmission fluid change bribri DIY / Maintenance / Service 4 01-01-2012 10:39 AM
Super Amazing Oil Change DIY id3379 DIY / Maintenance / Service 34 11-28-2008 01:20 PM
