Old 04-15-2013, 10:17 AM   #1
esse10
Drives: 2009 yaris 2 door
Bearing
Is this internal shaft bearing only in the automatic tranny's??? seems very low miles for something like that to go bad so soon..HHMM??
Old 04-15-2013, 11:10 AM   #2
The OP is the first person that I've heard of having it fail.
Originally Posted by yaris4062007 View Post
my car viberates around 75mph and at 80mph+ it gets worse, it makes weird noise too. could it be wheel bearing or shaft bearing?? does bad wheel bearing viberates too?? I can hear the noise coming from front left side, not sure from left wheel bearing or from transmission. thank you..
If it was a bad tranny or wheel bearing you would likely hear/feel it before the 75 MPH mark. You may simply have a tire that is out of balance.
Old 04-15-2013, 12:59 PM   #3
esse10
vibration
Hey thanks CTSCOTT , The last time I saw vibrations in my front end when I got to 60-70 mph it wind up being the inner CV axle gone bad, in my VW car though. It could also be front shocks/struts or out of balance tires/wheels like stscott suggested.
Wheel Bearing? devinlamothe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 07-12-2015 12:59 AM
Alternator Bearing barryware DIY / Maintenance / Service 7 11-23-2013 06:33 PM
Effects of too much trans fluid in the case? (auto trans) detroiter General Yaris / Vitz Discussion 5 02-24-2009 11:08 PM
The Official Having A Bad Day Thread. *MAD DOG* Off-topic / Other Cars / Everything else Discussions 7 11-15-2008 08:38 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
