Old 04-15-2013, 05:19 PM   #1
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
DRLs were standard equipment for 2008 and 2009, so the prior owner may have disabled yours. If you want to know for sure if it was built with them, shoot me your VIN, or take a look under the dash above and to the right of the steering column for the DRL module.
I found it in my PM history and PM'ed it to ya again in case you deleted it. :) Thanks!
Old 04-15-2013, 05:25 PM   #2
I forgot about having looked up the keyless entry piece for you...
It turns out your car does not have the DRLs. For 2009 it was part of the cold are spec, and yours was not built with that package.
There is a different under dash harness for ones with and without it, so unfortunately adding them is not as easy as plugging the module in. The easiest way to add a set would be to use one of the Phillips DRL kits.
Question about lights kaymm General Yaris / Vitz Discussion 4 04-20-2020 09:10 PM
- DISABLED DayTime Running Lights How To- 2007 Yaris! - Chris07LB DIY / Maintenance / Service 266 09-04-2017 03:34 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
DayTime Running Lights ISSUE!!!??!?!?!?!2009 5-door-hatch powermicro In Car Entertainment + Electronics (audio / video / alarm) 1 05-14-2009 12:12 AM
Does the Yaris come with............. Driver Cosmetic Modifications (Exterior/Interior) 7 08-21-2006 12:06 AM
