Old 04-20-2013, 03:07 PM   #5
Tomatogrower
The Flying Tomato
Tomatogrower's Avatar
Drives: 2009 Red Yaris Hatchback
Do you have power locks? Or power windows? I'd think more crossed/stripped wires than anything good.
I have manually cranked windows, not powered ones. There are motors that are driving the locks to lock/unlock when this happens, but I do not have any buttons within the Yaris that I can press to lock/unlock all or any doors. Before this all started happening, I would have to manually lock/unlock each door.
It appears to me that the problem is controlled rather than intermittent, I just don't know how it was induced/started. If it was due to shorted/stripped wires, wouldn't I see it more as an intermittent issue in the beginning rather than it happening consistently all the time like I'm seeing right now? Thanks!
The 09 Yaris did not have that as a feature of the OEM power locks / keyless entry, so I would bet that your Yaris has an aftermarket keyless entry system installed. Take a look under the dash, below the steering column, for the aftermarket module.
I would be surprised if an aftermarket keyless entry system was installed. I bought the car new from the dealer with ~20 miles on it. When I installed foglights a few months back, I didn't come across any wires or assemblies that seemed out of place or any that appeared to be aftermarket. Do you know off-hand if the newer/older models have that as feature? If so, which ones? Thanks!
Tomatogrower is offline   Reply With Quote
Tags
automatic lock sequence
Installation of original power windows and locks in Yaris lantis DIY / Maintenance / Service 4 02-25-2012 01:38 PM
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Power windows and locks on a 2009 3dr. chilly79 DIY / Maintenance / Service 8 12-15-2010 12:55 PM
Should I buy an automatic? ktoyo New YARIS Purchase Forum 40 06-23-2010 02:09 PM
Adding Automatic Locks MrJester DIY / Maintenance / Service 15 06-08-2007 01:02 AM
