Old 04-21-2013, 06:01 AM   #5
bronsin
bronsin's Avatar
That series of codes indicates that the system lost pressure while doing the evaporative check that the system initiates when the car has been powered off for 5 hours.
It very well could be the gas cap, but also could be the Purge VSVm or the canister itself, or the lines between the VSV (under the hood) and the canister (at the rear of the car).
You won't see any obvious effects, as this whole thing is purely a vapor recovery system, and unless the primary vacuum hose to the VSV fails, you will never see it effect how the car runs.
So it wont hurt the car to run it?
Is it true most of the error codes wont hurt the car if not fixed?
What error codes should we be worried about in terms of dammaging something?
Thanks!
Tags
check engine light, p0441, p0455, p0456
help..check engine again dindy DIY / Maintenance / Service 12 12-13-2012 06:17 PM
Check engine light Geelmeel DIY / Maintenance / Service 7 11-28-2009 11:32 PM
Check engine light flashes during high reving AlphaFox DIY / Maintenance / Service 40 08-21-2007 01:43 PM
Check Engine "Injector failure Code" YarisPR DIY / Maintenance / Service 14 03-04-2007 08:13 PM
