#1 | |
That does sound familiar with the 07's not having the gear displayed (08+ definitely does though). The switch on the tranny that the shifter drives is the Switch Assy, Neutral Start (84540-46010). Although the name doesn't imply it, it feeds all of the gear positions to the ECM.
#2 | |
![]() Drives: Yaris Join Date: Nov 2015
I have recently changed out my battery and alternator on a 2011 Yaris with automatic transmission and 82K miles. After I did that the CEL continued to come on after a couple of drives. The code that came up is P0705 and now the gears do not show up in the display. I have checked all fuses and none have blown, including the 10A GAUGE fuse under the bottom of the dash. Since changing out the alternator and battery everything has been running great. The only issue is the CEL coming on and I am unable to see what gear I am in. Other than that, the engine continues to shift fine. I have also checked all connections and they are clean and firmly attached. Thanks for any input. |
#3 | |
Putting back on
I finally got the Switch Assy, Neutral Start (84540-46010) in and am in the process of replacing now. Here is the problem:
I got the old switch off, it was on there really good and I needed to pry it off. Now when I go to put the new one on it is just as tight if not tighter. I have cleaned the rod coming out of the transmission where it slides on and have separated the opening as wide as possible on the switch. Any ideas on how to get it back on? No room to get good whacks with a hammer. I had to use a little pry bar and hammer to get the old one off. |
#5 | |
pics
Here are a couple of pics.
| P1345 Error code | Nicholas2003 | DIY / Maintenance / Service | 0 | 02-03-2013 06:47 AM |
| p0705 code | attickt | DIY / Maintenance / Service | 7 | 01-22-2013 11:27 PM |
| QR Code Window Stickers | nick.dollimount | Cosmetic Modifications (Exterior/Interior) | 23 | 02-25-2011 06:22 PM |
| 2010 RS Model Code?? | revolution | Cosmetic Modifications (Exterior/Interior) | 10 | 10-14-2010 05:11 AM |
| Yaris CDX 1999 P0171 error code | Davax | DIY / Maintenance / Service | 2 | 08-18-2010 07:14 PM |
