![]() Drives: 2007 Yaris 3door white Join Date: Apr 2013
Will this hold? Plastic bag vs brake fluid
Sorry for the consecutive threads and questions guys.
I havn't been driving for a couple of days, moms been using my car. After when she got home she told me about the ABS lights being on for a couple of days now. When i checked it, it turned out to be the rubber plug for the brake reservoir has been ripped and i've lost so much brake fluid. It went considerable past the minimum line and theirs brake fluid all over the rubber pipes below it. When examining the rubber plug, it does not appear to be of high quality when i pulled n tugged at it. My question is will this be alright for a few days until i can find something more solid to plug it with ( i dont want the fluid to absorb water when leaving the car outside)? I cut out a piece of plastic and wrapped it around using it as a plug with some duck tape around the edges. I can't find where to buy this rubber plug or whats its called over google or ebay. Dot 3 come in plastic bottles but this is a cheap plastic bag as per the pic so im not sure if dot 3 will eat away at it while i look for something solid to replace it with Heres a pic ![]() ![]() EDIT: Im not gonna drive it of course, its just for protecting the fluid from gathering moisture. Last edited by lamadoo; 04-24-2013 at 12:12 PM. |
Brake fluid will eat through the ziplock bag. Not all plastics are resistant to brake fluid.
#3 | |
Im thinking of making a solid plug or so tmr, idk what with. Last edited by lamadoo; 04-24-2013 at 09:05 AM. |
Most hardware stores have a cabinet in the hardware area with various size rubber stoppers. I would try to find one of those that fits.
Thankss, ill get one first thing tommorow !
#6 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
make sure you clean up the fluid it will eat paint and be a pain to repair the damage from.
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
Thanks guys, when my mom got back i flushed it with water but unfortunately the damage was doen already. Its only a small small spot in the inside corner (can't see it unless you stick your head under). Its nasty stuff indeed, corroded the paint really fast.
Looked everywhere in town and finally found this nice rubber blank cap thats a perfect snug fit at one of the hardware shops, i dont feel the need to clip itl. A lot thicker and durable than the oem plug. Only costs a couple of dollars Heres a pic of the leaked/ripped stocked one and the new off-market cap. Dot 3 was eating through the oem cap because it was really thin and made it very hard at the tip and protrude. Now that i learned my lesson, i will change or check it at every bleeding intervals. :)
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 08:50 AM |
| Can we change the Brake Fluid this way? | lamadoo | DIY / Maintenance / Service | 11 | 04-15-2013 01:09 AM |
| Should I change my brake fluid? | lh59 | DIY / Maintenance / Service | 4 | 06-26-2012 11:48 PM |
| red hot brake shoes | tommo | DIY / Maintenance / Service | 1 | 08-31-2011 07:34 PM |
| Anyone care to make a DIY on break flushing and bleeding? | Hard_Yaris | DIY / Maintenance / Service | 19 | 05-04-2011 03:49 PM |
