Old 04-30-2013, 02:33 PM   #9
TOLMACH
Drives: soarer
Originally Posted by jcboy View Post
the reason why you keep breaking fuses is that the relay's feed in 85 (from the stock wiring's +12V) is now shorted to 86 (ground) (or vice versa, whichever way you did it).
change your relay, and yes, weatherproof it, and youre good to go.
here's the connections as a refresher:
stock wiring +12V --> relay 85
battery +12V --> relay 30
horn +12V --> relay 87
horn (-) and relay 86 --> body ground
if you want you can insert an inline fuse from battery +12V to relay 30, your best bet is somewhere closer to the battery than to the relay.
makes sense?
^ This is nice.. will save for myself - needed ignition controlled power for my gauges recently (now fed through cigarette lighter.. will change now)
My horn install... Goose DIY / Maintenance / Service 7 01-29-2016 04:10 PM
Toyota Premium Horn Install Meteorite_Marty DIY / Maintenance / Service 78 02-23-2013 02:02 PM
horn install ttr125fan09 Cosmetic Modifications (Exterior/Interior) 6 06-23-2012 07:42 PM
