Old 05-03-2013, 11:37 AM   #1
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Originally Posted by kou View Post
^^ If you have no codes and canada does not do sniff test on exhaust you will pass inspection without a cat installed. If they do sniff test you will fail if you have no cat.
I've been wondering this for awhile, since you're 'supposedly' allowed one unready status. If you have both O2 sensors in, only the catalytic converter efficiency threshold would show up as unready...
If that's the case, I need to go get inspected.
Focus_Sh1ft is offline   Reply With Quote
Old 05-03-2013, 11:48 AM   #2
kou
Drives: 08 lb
Oh and if you dont have a cat or something that looks like a cat in place you may have problems if they get the mirror out to look under the car. Take it to a private shop may be better as long as OBD is clear they might not mind as much if you have no cat.
