Old 05-01-2013, 03:17 PM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
FUNK
Ive had a few cases of the vent funk so i ran off to Home Depot and bought a bottle of spray CONCROBIUM. I gave my Yaris a couple sprays in the store parking lot--time to see if this sh-- works. First test was the 25 mile trip to my house. I ran the ac and the all the vent systems,the blower etc. etc.outside air,inside air the whole 9 yards...... NO FUNK.........YET, I'll keep in touch.
peewee1 is offline   Reply With Quote
Old 05-03-2013, 10:41 AM   #2
peewee1
PEEWEE1
peewee1's Avatar
funk 2
Just to stay on top of things I lightly sprayed(6/7 squirts) concrobium down the outside air intake vents. Ran air hot and cold and all vents,all settings all random stuff to circulate the air.Drove @25 miles=no smell..At the first sign of funky smell I'm going to check that the ac drain hose is open and properly draining.....
Old 05-03-2013, 02:21 PM   #3
BLH
Drives: 2007 Yaris Sedan
Have you also verified you have a Cabin Air Filter?
My 2007 shipped with none installed. I understand most Yaris's where like mine. None from the factory.
BLH is offline   Reply With Quote
Old 05-03-2013, 02:38 PM   #4
Yup, had to make my own reusable cabin filter. Just cleaned it a couple of weeks ago, caught so much dirt. Pretty disgusting.
Anywho, it's suggested that you turn off the AC and put the fan on "fresh" air a mile or two before you destination to, I guess, clean out the system of the AC since it causes moisture (???) if left on until the destination, and will let mold grow (???), which is what causes the funky smell? I haven't dealt with the funky smell by following that.
Old 05-03-2013, 08:13 PM   #5
peewee1
PEEWEE1
peewee1's Avatar
cabin filter
Yes I have a new cabin filter installed one month ago.
Old 05-03-2013, 08:18 PM   #6
peewee1
PEEWEE1
peewee1's Avatar
ac drain
Have you checked the drain hose for the ac, to be sure its draining...Backed up water collecting in the ac will stink....
Old 05-04-2013, 05:10 PM   #7
peewee1
PEEWEE1
peewee1's Avatar
ac drain
Yes, if the smell comes back, im checking the drain hose.
Old 05-06-2013, 06:12 AM   #8
peewee1
PEEWEE1
peewee1's Avatar
ac drain hose
Checked and probed the drain hose= completely dry, not plugged.....
Old 05-06-2013, 11:10 AM   #9
padre1964
padre1964's Avatar
Drives: I'm back !! 2012 Toyota Yaris
I highly recommend Klima-Cleaner. Can be readily available online. Have not seen it sold locally. It's under $20 but worth every penny. I used it on my 09 and it eliminated that wet dog smell instantly. Still have plenty available incase my 2012 has the same issue.
best mpg so far, 46.1 !! Still shooting for 50 !
padre1964 is offline   Reply With Quote
Old 05-06-2013, 11:14 AM   #10
padre1964
padre1964's Avatar
I believe what you have is mold that is present since the condenser doesn't drain properly. I would imagine it is not very safe to inhale which is why i took care of it immediately
Questionable funk from the air vents SilverBack General Yaris / Vitz Discussion 25 02-03-2009 12:07 PM
