ok maybe it should say "87 or higher, within reason"
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
Well, with all the
I can only draw the conlusion that we should do what we want with our own cars. If you don't like cheap gas, run something higher. If you don't like high octane, run cheap stuff. 'nuff crying about it, just split the difference and run mid-grade as I do
...also the "xx or higher" is the industry standard for recommending fuel. so my lexus gs430 says "93 or higher" which really doesnt make much sence, because 93 is the highest pump gas avaliable in north america... toyota is saying "use 93"
the yaris says "87 or higher" which really doesnt make much sence because you cant get anything lower than 87 in north america ...the industry standard is to recommend the octane then add "or higher" at the end "....using a higher octane gasoline than your owner's manual recommends offers absolutely no benefit. It won't make your car perform better, go faster, get better mileage or run cleaner. Your best bet: listen to your owner's manual." http://www.ftc.gov/bcp/conline/pubs/autos/octane.shtm why do people insist on ignoring empirical and statistical data?
Last edited by fu_im_from_texas; 06-27-2007 at 02:34 PM. Reason: double re-edit typo |
#4 | |
heheheh too much science studies is just pushing me to experiment, if only I had that toyota intelligent tester or something similar to measure actual spark advance ![]() Or, we can find a Toyota ECU engineer from Japan to enlighten us?
#5 | |
Heart Up! Vitz
Like Tom said, just use mid grade. If its used car use cheap stuff. If its a new car in your first hands, use mid grade. If its hp is 173+ use premium~ |
#6 | |
![]() ![]() Drives: Yaris 3 Door, 04 WRX, 69 Lotus Join Date: Apr 2007
If anything, an older car needs higher grade gas because of bad maintance, wrong plugs, carbon buildups in the combustion chamber, etc. But, if a car is maintaned, there is no reason what so ever to use anything but 87 octane. I have been to gas stations that don't sell less than 89, and I've been to some that sell 86... There are a great many cars that make more than 170hp that only use regular. For example: My last truck was a V6 S10 that made 200-ish, and ran best on 86. The Jeep I traded in for the WRX made 235hp on 87. |
toyota
i find the yaris timing is right on the border of you being able to use 87 octane. slight change of slopes and temp even with its ecu adjusting..gives you a sluggish feel...89 got better outcome..its could also be just my car.. "Dont you guys notice a whirring sound when you accelerate , try driving beside a wall" i need to know if this is normal. or a slight knockin on the engine?
#8 | |
#9 | |
Mr Attitude
Drives: Blazing Blue 5 Spd Join Date: Jun 2007
As for the whirring sound, it's probably exhaust noise. As quiet as these cars are, there is still some noise. It dissipates easily normally, but a wall would reflect it back to you... |
#10 | |
Drives: 2007 Yaris LB Join Date: Mar 2007
I know the sound you're talking about....my old '97 Camry did the same...that sound is NOT pinging...it is just the fuel injectors doing their thing....yea, my Yaris does the same thing when I drive near a wall....again, not pinging, just valve and injector noise....no worries. |
#11 | |
toyota
thanks pavel.
toyota
thanks guys hopefully its nothing...
![]() ![]() ![]() ![]() Drives: 2007 Toyota Yaris Blazing Blue Join Date: May 2007
This topic always comes up on every forum that has to do with something that uses gas. It also turns into a huge debate taking up several pages and ending with the same result. The same goes for the big debate between using synthetic or natural oil.
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
ok there is stuff higher then 93 in north america its ether 94 or 95 from shell or sunoco
"It hurts more when its wet" |
wow, i can't stand to read this thread anymore, and it's my own thread. lol...
![]() Drives: 2007 Toyota Yaris Sedan Join Date: May 2007
I usually get 87, but i got 89 once and it was about the same with mpg. since I have had my car i've always used shell gas, don't plan on using another brand. I've always been weird with gas and my cars, always fill up the same place, usually the same pump. Unless of course im on a trip, but then ill still use shell.
![]() ![]() ![]() Drives: None Join Date: Mar 2007
Using higher octane than recommended will NOT make the engine knock*. It will make it less likely to knock. Higher octane = more stable and less likely to prematurely combust.
Members in this thread are correct in saying that you will most likely have no benefit from increasing the octane rating on the fuel (unless your car knocks at the recommended amount). The top fuels (98 RON) are there to replace leaded petrol. Back in the day, lead was THE way to boost octane. Now we can achieve higher octane ratings without it, there is no need to burn lead in old cars. *Heh, I just read the last couple of pages and I don't think anyone said it would. Nevermind then.
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
| I'd like to know this right now.. is brand name gas better for my new Yaris? | fantabulousbaby | General Yaris / Vitz Discussion | 12 | 09-19-2006 09:14 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 08:07 AM |
| Tired of poor gas mileage & buying premium gas. | Boosted Peon | New YARIS Purchase Forum | 29 | 08-25-2006 08:59 PM |
| poll concerning gas prices | foober | General Yaris / Vitz Discussion | 15 | 07-24-2006 12:47 AM |
