Old 04-04-2007, 12:55 PM   #1
I believe the question should be, are those "cleaning additives" and othe rmagical things you pay for in fancy fuels anything more than marketing gimmicks? Is there any independent testing to show it actually does anything?
Don't ya just love capitalism?
yeah, i've always wondered that too, but seeing how Shell, Chevron, and the other companies that say they have these "cleaning additives" perform better than those el cheapo gas, i slowly started thinking less about it.
Kaotic Lazagna is offline
Old 04-04-2007, 01:45 PM   #2
the more expensive cars that i've had got less mpg. then again, the Camry and GTI used always used plus with a tank of premium once-in-a-while, unlike my Yaris, all regular except that one time.
Old 04-04-2007, 01:57 PM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
try it..
try filling up with regular and track km or mile then fill up with premium...the car i drove which is cavalier full tank regular run me about 330 km then switch to premium im constantly running over 360... my celica regular will run the same 310-320 with premium 360-370..and im doint same thing week after week..work to friends houses...
marcus is offline
Old 04-04-2007, 04:18 PM   #4
Pavel Olavich
Drives: 2007 Yaris LB
THAT IS A CAVALIER!!!! How can you assume that what works for a Cavalier will work with a Yaris?!?
Pavel Olavich is offline
Old 04-04-2007, 04:35 PM   #5
marcus
toyota
marcus's Avatar
...you again!!
hey its not just the cav its the celica gts, 94 honda civic si, mitsubishi lancer es., 95 acura integra, camry 95.., want me to go on... but hey use 87 its ur car...all that matter is physical evidence...its kinna like a dead guy teling you how he got killed using forensic .
marcus is offline
Old 04-04-2007, 04:40 PM   #6
Pavel Olavich
Marcus,
2006 Mustang, 2007 Yaris, 2003 Expedition, 2002 Camry, 2004 Camry, 2005 Civic...these ALL get worse gas milage when using premium....but these are not Yaris, so this list and YOUR list is irrelevent.
All cars, regardless, will get better milage when one uses the octane the car was tuned for...this is the optimum for best performance.
The Yaris will get worse milage with Premium...it's sad that superstitions die hard....
Stop listing other cars....lets talk about the Yaris.
YARIS!
Old 04-04-2007, 01:59 PM   #7
i don't want my Yaris to get used to premium, so i'll test it out again in a month, or when ever the gas prices goes down a bit. premium can get close to 4 bucks here.
Old 04-04-2007, 02:40 PM   #8
marcus
toyota
marcus's Avatar
convert to diesel!!!!!!!!lolz....
marcus is offline
Old 04-04-2007, 02:43 PM   #9
lol...don't know why, but diesel is sometimes more expensive than regular.
Old 04-04-2007, 07:46 PM   #10
Edd
Drives: None
Your regular is only 87?
Ours:
Regular - 92
Premium - 95
Optimax™/Ultimate™ - 98 (The name is different with each company)
EDIT: Apparently the number is calculated differently and the fuel is the same thing - shown here.
Edd is offline
Old 04-05-2007, 10:47 AM   #11
marcus
toyota
marcus's Avatar
yup!
canada
regular = 87
premium = 89
gold = 91
sunoco= 94 highest..
Ours:
Regular - 92
Premium - 95
marcus is offline
Old 04-05-2007, 02:00 PM   #12
Dragonacc
Drives: 07 Yaris LB, 70 Mach 1, 84 5.0
I agree with the others on that say higher octane will not give better fuel economy (unless the ecu changes the tune because of it). There are a limited number of cars out there that have ECUs that will adjust the tune of the car based on the octane of the fuel.
Usually the ECUs that have this feature only actually work in reverse. They change the tune when you put lower octane fuel in and it hurts performance and fuel economy. This is because those cars were designed to use higher octane fuel to begin with.
Anyone that says their car get better mileage with premium is probably just driving it better because they just got raped at the pump.
Dragonacc is offline
Old 04-05-2007, 02:09 PM   #13
marcus
toyota
marcus's Avatar
i think im getting what other people are sayin..only because you guys already are using 89 and above so it doesnt make the diff..in fact u may lower ur gas mileage as well..in canada yaris is running on 87 octane gas..and 90 % of cars out here.. big difference on 87 to 89 without any exaguration ull notice the diff right away swiching to 89..gas mileage is actually higher with the 89 octane gas..and that is based on my experience with multiple differents cars out here...then again i dont drive high end cars..bmw,lexus,infiniti..etc....
marcus is offline
Old 04-05-2007, 02:27 PM   #14
ChinoCharles
Drives: LB
Aren't there some warranty issues with putting 93 octane fuel in a car rated for 87 from the factory? You guys putting high-grade fuel in Yarii better hope we don't find out later on that she doesn't like it. Fuel systems aren't cheap.
ChinoCharles is offline
Old 04-05-2007, 02:35 PM   #15
marcus
toyota
marcus's Avatar
i dont know about dealer issue!
you may need to ask ur dealer all i know is it should run atleast 87 octane or up..it didnt say just use 87. then again 93 octane has no diff with 89..the only time it will make the difference is you adjusting or advancing ur timing and that will give you faster acceleration..make sure its not too advance...but the only thing that i dont know is if the yaris ecu will automatically bring the timing down again after you advance it..
Isn't there some warranty issues with putting 93 octane fuel in a car rated for 87 from the factory? You guys putting high-grade fuel in Yarii better hope we don't find out later on that she doesn't like it. Fuel systems aren't cheap.
marcus is offline
Old 04-05-2007, 02:36 PM   #16
marcus
toyota
marcus's Avatar
Advance timing requires higher octane gas..otherwise ur engine will knock..i have been doing this on my celica for the past 6 years it gives me faster take off with 94 octane from sunoco..but uses more gas though..then i bring it down on winter...1 bolt on the cam to adj. takes less than 2 minutes.. timing gun nessesary..
marcus is offline
Old 04-05-2007, 02:38 PM   #17
ChinoCharles
Drives: LB
OK, so I can go put 110 octane in it?
Old 04-05-2007, 02:41 PM   #18
marcus
toyota
marcus's Avatar
whoah!!!
whoah easy there chino... might as well put sum jetfuel in there....i dont know how much tadvance timing can our yaris take though...check advance timing thru google.. maybe itll tell you... easy on the engine its only 1.5l....
marcus is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
