Old 04-11-2007, 11:00 AM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well u see...
as per (Adriaan's) quote.
"he personally i like the premium gas, i've has lots of problems with the regular gas here in ontario. The gas here is mixed with ethanol some times up to 15% except shell premium and i believe pioneer. i was having problems with the gas sensor. Took it to the dealer to find out that the since i was mixing fuel with and without ethanol the fuel turned a white color and had damaged the sensor. i work between montreal and toronto. In Montreal there is no ethanol in the fuel as of yet. Since i had it changed i stop buying regular here in ontario and haven't had the problem since. Also I work for esso and i found out that when you mix ethanol fuel like sunoco with regular fuel with out ethanol turns a white color, and as of yet there no technology to separate the two. But this is my experience and what i found out. Not sure if it is true with what i found, or my car was and isolated incident. Also i did a test with sunoco ultra 94 and shell premium on my last trip to montreal. Between my monteal house and toronto house is 686km with ultra 94 i got 536km and with shell i got 636km same driving style going and return about 120km to 140 km on the 401."
Originally Posted by Pavel Olavich View Post
So less efficient combustion means "cleaner"....Nope!
marcus is offline
Old 06-22-2007, 02:45 AM   #2
dallas
Drives: Yaris Hatch /Landrover D2
Let's stop the b.s and start posting our mileage figures on the two grades of gas. Enough people checking it should make the results more believable
dallas is offline
Old 04-09-2007, 06:48 PM   #3
Moose
Resident Redneck
Moose's Avatar
Drives: 07 Polar White Yaris Sedan 5M
I tried a tank of premium this week, after reading this thread, just to see what would happen. 90% of my driving is usually highway, and half of that is in bumper to bumper traffic. I usually average about 35 mpg. Using the premium, and with a 120 mile mountain run (most of which was spent at 4500 rpm and above) in addition to my normal routine, I averaged 37 mpg.
Will I spend the extra money on premium again? Nah, it wasn't that much of a difference to me. Did it prove to me that you do, in fact, get better fuel economy with 93 octane? You betcha, and I bet that I could've done better without the mountain run, as well.
My other rides:
2003 Honda Civic LX Coupe 5M- S/C K24 w/ LSD coming soon!
1999 Honda Civic EX Coupe 5M w/ B18 powaa
1985 Toyota Celica GTS Coupe 5M- track whip
http://www.importlounge.com
Moose is offline
Old 04-10-2007, 01:07 AM   #4
cool, cool, this premium stuff is weird.
Kaotic Lazagna is offline
Old 04-10-2007, 04:30 PM   #5
Pavel Olavich
Drives: 2007 Yaris LB
Your 'test' was not scientific....did you every consider that you could fill your tank up with 87 octane and drive your same route 10 times and get ten different MPG results? Your test lacks controls to be able to draw conclusions. Funny how you do your test once, and draw conclusions....did you attend college?
Pavel Olavich is offline
Old 04-10-2007, 04:40 PM   #6
acrbill
Drives: Polar White Hatch
The Yaris has 10.5:1 compression. It must have a extremely conservative timing curve to allow the car to run on regular. My old Neon ran on premium. It said premium fuel recommended. It did not say required. If I put regular fuel in the MPG would go down like crazy and there would be a noticeable power loss.
IMO any car with that high of a compression ratio should run better with a slower burning fuel in. The real test would be to use a obd2 data logger to monitor the knock sensor and timing with regular and premium. I would bet that you will see a lot of activity from the knock sensor and therefor timing being pulled and fuel being dumped.
http://home.comcast.net/~job0b/ywsig.gif
ChinoCharles Intake supporter.
acrbill is offline
Old 04-10-2007, 05:42 PM   #7
Pavel Olavich
It's not just about high compression....the amount of cubic liters comes into play....just because a small engine has high compression does not necessarily mean it requires premium....you need to take the size of the engine into consideration too. The bigger the displacement, the longer it takes for the fuel to burn completely, thereby requiring more octane to retard the burn for a given stroke.
Old 04-10-2007, 05:46 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
let us pull that Chino quote again "Do you ever shut up?"
Black Yaris is offline
Old 06-25-2007, 01:30 AM   #9
Moose
Resident Redneck
Moose's Avatar
WOW. I just saw this.
Is this guy still here, or has he been banned?
1) ...did you every consider that you could fill your tank up with 87 octane and drive your same route 10 times and get ten different MPG results?
Yes, and they are usually within .3-.5 MPG each time. I actually do the math and keep a log. That's as close to scientific as we can get.
2) Your test lacks controls to be able to draw conclusions.
As does your opinion.
3) ....did you attend college?
Yes, Georgia Tech. I actually know the science- you think you know the science. And don't try any cute comebacks- I'll just look at my degree and my paycheck and giggle.
Will there be anything else Pavel? I generally reserve arguing on the internet for times when I have nothing more adult to do, but watching you unravel and make a fool of yourself is worth it.
My other rides:
Moose is offline
Old 06-25-2007, 06:03 PM   #10
Pavel Olavich
Your testing methods belie your "Georgia Tech" education. Sorry, but it was sloppy....by the way, I'm sure your giggling paycheck would make me laugh off my ass too!
Old 06-25-2007, 06:59 PM   #11
Moose
Resident Redneck
Moose's Avatar
My other rides:
Moose is offline
Old 04-10-2007, 05:54 PM   #12
Slummy
Slummy's Avatar
Drives: Black LB
I know that acrbills test was not "scientific", but dont all his previous tanks that average 35 MPGs act as a control? Not trying to be difficult. Just curious.
Slummy is offline
Old 04-10-2007, 05:56 PM   #13
Black Yaris
der Zeck
yes... Pavel is just mean, he just does not want to face the truth that he is WRONG 90% of the time
Old 04-10-2007, 09:05 PM   #14
elsteverino889
elsteverino889's Avatar
Drives: 2007 Yaris sedan black
Go with Citgo...support Chavez!!!....i kid lol
I was 17-20 I lived the "Lifestyle". Fast cars, skanky hood rats, and stupid kids trying to prove who was faster. -Spades(the one and only street racer)
elsteverino889 is offline
Old 04-10-2007, 09:09 PM   #15
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Hey Pavel....you're great!!!
Haven't met many like you, but all I can think of is you sittin at home gettin under peoples skin and just laughin!!
Carry on.
____________
Old School Cobble Jockey
churp is offline
Old 04-10-2007, 10:34 PM   #16
Black Yaris
der Zeck
Carry on.
1 vote to ban you from the site just for that comment
Old 04-10-2007, 10:48 PM   #17
acrbill
Just what any site needs. Some 8 year old who gets off by pissing everyone off.
99% of the time I would agree with Pavel, but the high compression makes this situation different than most.
By your logic you would lose MPG. So even that guys "unscientific" test points to that not being the case.
So everyone knows.
The higher the octane the slower the burn. You want the lowest octane that the car can function well at. Most of the time using higher than needed octane cost performance. With higher compression there is an increased chance of engine knock. Not even the audible type, just the type that the knock sensor picks up. When that happens the ECU pulls timing and in some cases dumps fuel. Both are bad for all aspects of performance.
The only real way to test would be to log sensor outputs and timing advance with both fuels.
acrbill is offline
Old 04-11-2007, 10:46 AM   #18
Adriaan
In between cities
Adriaan's Avatar
Drives: 2006 yaris ce
my experince with premium
Adriaan is offline
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 06:41 PM
I'd like to know this right now.. is brand name gas better for my new Yaris? fantabulousbaby General Yaris / Vitz Discussion 12 09-19-2006 09:14 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 08:07 AM
Tired of poor gas mileage & buying premium gas. Boosted Peon New YARIS Purchase Forum 29 08-25-2006 08:59 PM
poll concerning gas prices foober General Yaris / Vitz Discussion 15 07-24-2006 12:47 AM
