![]() Drives: 2008 Toyota Yaris Sedan Join Date: May 2013
The bulb is in working order the socket looks burned out, any ideas on replacement sockets and the easiest way to do that?
Replacement H4 sockets are easy to come by. Most autoparts stores stock them. You will have to cut the existing one off and splice the new one on. Solder and heatshrink is the best way to do so.
Thank you for your help...now to find an excuse to install foglights...
It is easier to replace the connector with the headlight removed. which requires disconnecting the top of the bumper, and hence is the perfect time to do the fog light install.
#6 | |
http://shop.microimageonline.com/Fog...?categoryId=-1
UPDATE: I replaced the socket and yet the passengerside high beam still does not work...any suggestions? The fuses are all in working order.
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
| How can I get in touch with Toyota Regional Offices in Houston? | woof | DIY / Maintenance / Service | 11 | 11-28-2009 09:29 PM |
| HOW CAN I KEEP FOGHLIGHS ON WITH HIGH BEAM? | derickveliz2 | DIY / Maintenance / Service | 27 | 03-25-2009 04:53 PM |
| High Beam Issues | urbanmindz | In Car Entertainment + Electronics (audio / video / alarm) | 0 | 03-19-2009 09:22 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 09:12 PM |
