Old 05-10-2013, 10:30 PM   #1
yours_falsely
yours_falsely's Avatar
Drives: 2008 Yaris sedan
Auto. So, If I'm using the switch I don't need to connect to the ECM? Do I ground the other side of the switch or connect it to the brown? I apologize for all the questions, I've been trying to get this to work for a while now so I just want to make sure.
yours_falsely is offline   Reply With Quote
Old 05-10-2013, 10:34 PM   #2
If you are doing switches you don't connect to either of the D3 pins, but you do connect one side to the ECM (since he is doing the CC work) and the other side to ground:
Definitely check your resistors as well. A common mistake is to have values that are 1000 times what they should be.
GT5 Gran Turismo 5 Bluevitz-rs Off-topic / Other Cars / Everything else Discussions 144 03-04-2011 09:13 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
