![]() Drives: 08 3dr LB Join Date: Feb 2013
Hey Scott. Off topic. Can I put a cluster with tach into my 08 which only has speedo? Would I have to run new wire, or like the cruise, plug and play?
It is plug and play as long as you match if your car has ABS. If you don't have ABS, that limits you to 08 and older clusters. You can use 09 and newer ones, but some of the indicator lights (ABS, TRAC, VSC) will stay on, unless you internally cover or remove them.
| Tags |
| change, cluster led, color, speedometer, tach |
| WTD: ECM, Instrument Cluster, Headrests, Quarter window | chrisjaldin | Willing to Buy by private party | 8 | 09-03-2011 12:12 AM |
| Cruise Control - 07/08 Sedan - Instrument Cluster | CB900F2 | DIY / Maintenance / Service | 4 | 02-23-2011 08:03 AM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 11:05 PM |
| Instrument Cluster Swap | thepaidtraveler | Cosmetic Modifications (Exterior/Interior) | 28 | 11-24-2008 10:53 AM |
| instrument cluster swap S -> LB | elo79 | Performance Modifications | 1 | 12-21-2006 11:22 AM |
