![]() ![]() ![]() ![]() Drives: 06 Yaris HB CE Join Date: Aug 2009
Yes, I am wondering though if I do with 26AWG which is ok, but what happens if I plug in a power inverter or something that draws a lot of energy in the cigarette lighter which will brings a lot of current, is it going to have problems or burn out my 26AWG that is attached to the cigarette lighter wire?
thanks |
#2 | |
So, for your LEDs, my 25 above was based on a system voltage of 12V, as opposed to 14V when the alternator is spinning. When the engine is running you will draw less current than when it is off (higher voltage = lower current). I would recommend though installing a 2A or 4A max fuse inline with your LED wiring. The fuse for the lighter is 15A, so if you accidentally shorted your LED wiring the 26AWG wire would burn up, without popping the 15A fuse, so to be safe when you branch off a circuit with smaller wire you should always add a fuse appropriately sized for the branch wire.
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 01:20 AM |
| Scion XD LED mirror install pics aplenty | enviri | DIY / Maintenance / Service | 76 | 07-21-2019 02:10 PM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Blitz S/C being installed this Saturday! | LtNoogie | Forced Induction Forum | 179 | 12-14-2012 08:53 PM |
| Harman Kardon Drive + Play for IPOD | sroberts | In Car Entertainment + Electronics (audio / video / alarm) | 5 | 07-01-2006 01:05 PM |
