Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Marketplace > Willing to Buy by private party
Old 05-15-2013, 02:34 PM   #1
swidd
Drives: Yaris HB
Okay,.. so there are four wires going into the switch. But I only found two coming out of the harness + the ground wire. The other one must be hidden inside the harness or be merged with the red/yellow wire coming out. As I put it back together already, I'm too lazy to take it apart to check, unless it really becomes necessary. It's so hot outside...
http://i.imgur.com/MmYoWzs.jpg
http://i.imgur.com/AmcxmpE.jpg
The good news is that the fog lights are working, and the switch is working.
The bad news is that, at least as far as I can tell in super bright sunlight, the switch illumination is still on with the ignition off.
I guess I can snip the "third" red wire, i.e. the one next to the grounding wire, to resolve this issue? I don't really need switch illumination or dash light; when it's dark I can tell by looking where I'm supposed to be looking while driving, to tell if they're on.
swidd is offline   Reply With Quote
Old 05-15-2013, 02:41 PM   #2
The reason the light is still on is that the lighting and switching circuits are bridged. In order to separate them, you have to split all four wires apart.
Old 05-16-2013, 08:37 PM   #3
swidd
Drives: Yaris HB
Snipped wire, and nothing exploded. Now everything works perfect.
Thanks ctscott!!
DIY:Day time running light Disabled with stock fog light remain function summergxz DIY / Maintenance / Service 12 09-26-2007 10:42 AM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
Bulb Size For After Market Fog Light Kit razzorjet2 DIY / Maintenance / Service 1 04-10-2007 02:15 PM
Reverse light vs Rear Fog light cooldavidko General Yaris / Vitz Discussion 3 01-03-2007 03:09 AM
question on Fog light clfile Cosmetic Modifications (Exterior/Interior) 6 11-09-2006 07:11 PM
