Old 05-17-2013, 10:36 AM   #1
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
Hah that is awesome. I thought air rides were closed systems though??
Im so afraid my bbs are gonna leak when I reassemble them too :( Any tricks to avoid this?
Tails look great!
Old 05-17-2013, 11:30 AM   #2
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
Tails look great!
The tank had an extra port that was just sealed off with a bolt so we put a fitting in :)
Which bbs are you sealing up?
Either way get 100% silicone (think bathroom sealant) and use a caulk gun and lay down a nice bead of it around the mating surfaces.
If they are RS's you will lay it on the mating surfaces where the bolts go between the face and the lip. And more on the bottom side I believe. Just wipe off any that squeezes out when you torque the bolts.
Hers were fine last year, no leaks at all. This year I was in a hurry putting them together because there was a show coming up and they need to sit for 24 hours to seal and I ended up missing some spots. All good now though.
Here is the thread I used as a guide the first time I did it.
http://forum.wheel-whores.com/viewtopic.php?f=7&t=8518
Also a good thread
http://forums.vwvortex.com/showthrea...ding-BBS-RS-RM
sasquatch is offline   Reply With Quote
DIY Cabin Air Filter BailOut DIY / Maintenance / Service 105 06-20-2019 01:59 PM
$7 Ram air intake pictorial turbodiesel Performance Modifications 19 10-27-2008 06:46 PM
FE Mod ideas enkid Fuel Economy Forum 6 10-23-2008 01:01 AM
air filter multipart btc50 DIY / Maintenance / Service 1 08-31-2007 07:37 PM
Air Ride suspension for Yaris Sedan fouad84 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 7 10-13-2006 08:39 AM
