![]() Drives: 08 toyota yaris 5 speed Join Date: Aug 2010
2007 Yaris blinkers don't work HELP
Yesterday I changed the rear bulbs and believe I might have blow something. I just can not find out what it is. The hazard lights work but the blinkers do not. Also the car will only shift out of park if you use the shift bypass. Any tips or hints as to what I need to replace?
Returning to Toyota
Drives: 2013 L 3dr MT Join Date: Mar 2013
Did you check the fuses? Next, a bulb might not be seated right. I would take the bulbs back out and recheck your work. Look for damaged wiring.
Final thought: Try resetting the ECU by removing the Neg battery terminal for 10 minutes, then recheck. |
You popped the 10A GAUGE fuse in the fuse panel that is under the bottom of the dash. That fuse feeds both the shift lock ECU and the turn signal flasher.
+1 scott said check the 10amp fuse.
If I remember correctly. I only saw one 10 a fuse in the panel under the dash last night. Bit was on the left side. Is that the fuse you guys are talking about. Thanks for the quick responses!
No. look under the bottom of that area (literally up under the bottom of the dash) for the panel.
I will. Thanks Scott I will give it a shot tonight when I get home
Replaced the 10a fuse. Now the lights and the shifter work. HOWEVER now my ac will not turn on. No air blows out of my ac. Lights on the nobs work but no power. Where can I check for that. I figure it is another blown fuse. I checked in the same panel under ac and that fuse is not blown. Any suggestions?
Returning to Toyota
I'm guessing the fan does not run whither heat/no heat/ac is selected. Probably a fuse for the fan that is separate from the AC.
Just joking, maybe you should not work on cars? Really, it is hard to imagine what you could have done to cause this many problems just changing tail lights. Did you per chance do any thing else at the same time? |
HAHAH Well the reason I had to replace the tail light(s) is because someone threw a rock at my wife's rear brake light and busted the housing and one of the bulbs. I will say though I don't think I have ever had one get this buggered up over nothing. I just wondering what will happen when I change the oil next time....blown head gasket??....front bumper falls off??...The possibilities are endless
#12 | |
I know this is turning out to be car maintenance for dummies. Buuuuuuttt. If you are talking about a fuse on the panel above when i replaced the 10a fuse I do not see a 40a fuse there. Am I just missing it or am I not seeing the right thing or looking in the right place?
#14 |
Alright here is the tally. Rear back up lights do not work. Ac or heater do not work. Blinkers work. Shifter works. I have absolutely no clue how everything got this screwed up. Checked all the fuses I could find and they all seem fine(Replaced the 10a gauge fuse like ct scott recommended). This might turn out to be one of those take it to the people that get paid to do this kind of situation. This is just crazy.
#15 | |
#16 | |
#17 |
![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Sep 2009
#18 |
![]() Drives: 2007 yaris liftback Join Date: Jan 2014
2007 yaris blinkers don't work!!
Here it goes.. I already know I did something extremely dumb however I know being completly honest may help diagnose this easier. I was installing new aftermarket tailight assemblies on my 2007 yaris liftback.. stupid me was in a hurry and I wasn't paying attention..did it while the engine was running.. now heres the problem. blower does not work at any fan speed. also the light that indicates rear defroster is on, is constantly lit now. if i put the blower in any speed other than off, or OR push the button to power on the rear defroster, then my signals wont work
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 12:51 AM |
| 2007 Toyota Yaris Hatchback - 5-Speed Manual | truebreakerz | Cars for Sale by private party | 23 | 09-17-2009 09:29 PM |
