Old 05-20-2013, 06:50 PM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
I could actually make you a device that works off the VSS (speed sensor) wire. My Demetricifier (which lets a km cluster work as a Mile one) interprets that signal, so driving a beeper instead of manipulating that signal would be very easy.
I did some research of what is a speed sensor wire, it exactly like you said, outputs a signal to instrument cluster. If so any chance to just tap into that wire to the positive lead, and the negative goes to the yellow handbrake wire?
Old 05-20-2013, 08:36 PM   #2
You can't drive something with it, as it will drag the signal down. You could use a transistor to drive the buzzer off of the speed signal, since the signal sits at ground when the car is not moving and pulses at a fairly high frequency when the car is is motion.
Factory Alarm on my '08 Liftback is Too Sensitive! alex_melodymaker In Car Entertainment + Electronics (audio / video / alarm) 9 06-07-2011 03:21 PM
Alarm Wiring Advise Needed Lil Abner In Car Entertainment + Electronics (audio / video / alarm) 14 09-26-2010 10:11 AM
Keep your vehicle protected! sqcomp In Car Entertainment + Electronics (audio / video / alarm) 17 09-10-2009 02:02 AM
help me with my annoying alarm! misteo In Car Entertainment + Electronics (audio / video / alarm) 1 10-21-2008 01:49 PM
Rant! Damn car alarm installers, trying to rip me off!!!! W.A.S.P In Car Entertainment + Electronics (audio / video / alarm) 18 11-21-2006 09:18 PM
