Hi guys, next step in my project is running a standalone ecu (currently using aem FI/c). I would like to use the aem EMS, but I am not sure of some compatibilities with my 1NZFE...
Sensors that I know EMS will support/run easely (correct if Im wrong); 1.Mag crank sensor (already work with FIC, why not) 2.Mag cam sensor (already work with FIC, why not) 3. 370cc deatschwerks injector, 12.2ohm high impedance so why not. 4.Coolant temp, I will use aem unit... 5.Air temp, I will use aem unit... 6.Throttle position sensor (already work with FIC, why not) Sensors that I am not sure to be able to run; 1.My oem 1nzfe ''coil on top''?? 2.My idle air control valve with 3wires on the TB?? 3.Could I just use my aem wideband O2 sensor or I still need the original one? 4.Knocksensor?? Also there is 2 kind of wiring kit you can buy, first is a small one with no relay, second is a big one with relay & fuses... Which one I would need? Probably the big one since I dont know how I could still use the stock fuse/relay box. Thanks big time, and I know most of you guys run Yaris, so you may not answer my question about the idle air control valve (TB is dif from echo)... But thanks for help anyways! Last edited by maxthehax; 05-21-2013 at 03:13 PM. |
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
I think Jason@SportsCar is using an EMS as well, you should PM him
So is Garm from MicroImageonline.com
#4 | |
Yes he does, he is not using stock coil though, I think he used honda coil ignition... |
#5 | |
![]() ![]() ![]() ![]() ![]() Drives: 2015 H Production Yaris Join Date: Oct 2009
I am using nearly all OE sensors, along with OE coils and injectors. However, the factory MAF is now used only for air inlet temp because we are using an AEM MAP sensor. We are also using the AEM wide-band O2, the stock O2 is gone.
2005-2008 SCCA Solo BS National Champion 2017-2018 SCCA H Prod National Champion
#6 | |
#7 | |
Is there any other reason for you to keep the stock ecu installed? Thanks very much for your fast informations! Also, what about the wiring kit needed? Do you guys used the big 96'' with the relays & fuses? |
#8 | |
converting to cable throttle was not that difficult. We sourced xB pedal, cable and hooked it up to a Celiga GT-S throttle body.
You will need your stock ECU for power steering if you're keeping that. (I know there's a power steering ECU, but the main unit must be present.
OH WHAT THE HELL?
I was gonna go with the EMS and the plug in play harness so I can stay in STF for the rest of the year or until I go turbo.. But if I have to swap the throttle body out and run cable that will throw me into FSP.. son of a monkey! Thanks for this OP.. thanks alot! good info here.
#11 | |
![]() ![]() ![]() ![]() Drives: 08 Yaris Turbo; 06 tC Turbo Join Date: Jan 2010
What's the drawbacks of not having control over the throttle with the ems? I can't think of any outside of idle control... |
I think a plug and play harness are being made for the Yaris now. The AEM can control or read OE sensor's. The purpose of keeping the stock ECU is to control DBW and A/C. My suggestion would be to talk with your tuner he will know what you will need to do.
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
![]() ![]() ![]() ![]() Drives: 2008 Black Sedan Join Date: Oct 2008
there is an ems 4 pnp
http://www.treadstoneperformance.com...6-2013+BF14049 |
#14 |
why is one $100 cheaper than the other and what is the difference?
Eh. I guess if one was ready to purchase they could easily call and find out.
#15 |
so, what can this do that the EMS 2 can or can not do?
http://www.treadstoneperformance.com...+EMS+4+30-6905 This is much cheaper, is this a piggy back? All new to me
#16 | |
#17 |
![]() ![]() Drives: yaris 09 ncp91 Join Date: Nov 2011
boomslang made a pnp harness for 499$ http://www.boomslang.us/aem-ems-4.php
#18 | ||
Cable and wire were the same thing in my head :P sorry So I thank you guys, you answered all my question about the ability to run all sensors / TB, since I have a DBC I should have no prob. But what about the wiring harness I need!? :P Last edited by maxthehax; 05-23-2013 at 09:52 AM. |
| I finally cracked the Odometer and SRS ECU code | CTScott | DIY / Maintenance / Service | 22 | 10-27-2016 01:50 AM |
| AEM cold air intake vs Afe intake... | djgab101 | Performance Modifications | 69 | 04-28-2013 02:03 PM |
| New Engine Management System offered for the 1NZFE | Dezod | Forced Induction Forum | 51 | 06-16-2011 10:33 AM |
| Standalone ECU | d1nzfe | Performance Modifications | 11 | 12-24-2009 11:46 AM |
| FS: Motec M4 Standalone ECU w/ Ignition Expander | Biggie™ | Items for Sale by private party | 6 | 10-20-2009 02:36 PM |
