Old 05-21-2013, 04:59 PM   #1
peewee1
PEEWEE1
peewee1's Avatar
Drives: 2009 yaris s sedan
automatic down shift?
To all you expert yaris drivers/owners, is it advisable to downshift an automatic tranny when coming to a stop sign/light? I have developed a habit of going into 3rd gear from 4th gear when approaching a stop sign. Does this kind of driving have any effects on the "ecm", and its learning ability?
peewee1 is offline   Reply With Quote
Old 05-21-2013, 06:25 PM   #2
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
I'd say the trans knows what to do; just leave it in drive and let it downshift when it wants to.
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 05-21-2013, 07:51 PM   #3
jayeh
Drives: '08 Yaris LB
The trans knows what to do for the smoothest ride...
jayeh is offline   Reply With Quote
Old 05-21-2013, 10:29 PM   #4
MadMax
MadMax's Avatar
No reason for it, and it probably counteracts the DFCO which works to maximize your fuel efficiency.
I only downshift in my automatic when I'm feeling frisky and want to think my Yaris is a real sports car.
Oh, that and when I come upon steep hills!
Cheers! M2
Old 05-22-2013, 10:16 PM   #5
10 Francis
Drives: 2010 Yaris S HB
DFCO only works in an auto when you downshift...
10 Francis is offline   Reply With Quote
Old 05-23-2013, 09:44 AM   #6
MadMax
MadMax's Avatar
Wrong. Early versions of the AT (Including ones sold in the U.S. until around January 2007) can only achieve DFCO with a gear selection lower than (D)rive, i.e. 3 or L, but since half way through the 2007 model year the AT can achieve DFCO in all gears.
Downshifting is NOT required. The system will remain on until the accelerator is engaged, engine speed drops below 1,100 RPM or the transmission is put into neutral or the clutch engaged (on manuals).
Old 05-23-2013, 12:48 AM   #7
Aamya
Drives: audi
I have a question for all,.
Can you please tell me that Do you ever need to downshift in an automatic car?
Waiting for the answer,.?
Aamya is offline   Reply With Quote
Old 05-23-2013, 11:36 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Only time you would need to downshift is if you are driving in the mountains and going up a steep hill. Say that you are going up a hill and you hit the accelerator and it feels like your not moving and it wont downshift on its own and you don't wanna peg the gas too the floor. Then you would downshift to 3rd to keep the RPM's high so you got quick acceleration up a hill and you dont have to worry about the car switching back and forth from OD to 3rd.
-Derrick-
Old 05-23-2013, 10:54 AM   #9
Hershey
When the O.B.D ( drop to 3rd ) kicks in during a descent there's no change in F.E.. The Eco-Meter gains gas mileage .
Old 05-23-2013, 12:27 PM   #10
Amdkt7
Returning to Toyota
Drives: 2013 L 3dr MT
Nothing wrong with downshifting to reduce the use of the brakes. It helps reduce brake wear, and also helps keep the engine in DFCO (saves fuel). And yes, it does add wear to the tranny..... but how much? No more than upshifting, especially during high acceleration.
One caution, don't downshift so early that it makes the engine over rev. Personally, I don't like to downshift so early that my RPMs exceed 5K rpm.
Amdkt7 is offline   Reply With Quote
Old 05-23-2013, 02:58 PM   #11
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
Why would you ever manually shift an automatic? Automatic transmissions cost a fuckload more than a set of brakes. Use the brakes to stop and let the transmission do its own thing.
Old 05-23-2013, 04:37 PM   #12
Septembersrain
♣♀Yaris'ing♀♣
Septembersrain's Avatar
Drives: 2013 Yaris 3-Door LE ~Pearl~
Yeah. I can't see myself using the wanna be manual option in my automatic.
I think I could do way more harm than good in that instance.
I haven't actually driven a manual since I was 14.
I think if you want a manual, Buy one.
If you want an automatic, Don't make try to make it a manual.
Just my opinion anyways.
Everyone has their own idea of right and wrong.
Don't be a drip. ◄~(¬ _¬)~
Septembersrain is offline   Reply With Quote
Old 05-24-2013, 06:10 PM   #13
MadMax
MadMax's Avatar
I occasionally shift my auto, usually when driving a bit more aggressively than usual. If it wasn't designed to take it, then it wouldn't have that option. I am simply using it the way Toyota engineered it.
The nice thing is when I do want/need it to shift on its own, it can...
Accept it or not, but automatic transmissions are the future of motoring. Toyota sold considerably more automatics in the Yaris than it did manuals, and many cars are not even offered with manuals anymore.
Even in Europe, where the manual transmission reigned supreme long after it started fading in popularity in the States, it is now more common to see automatics.
The clock is ticking...
Old 05-24-2013, 10:28 PM   #14
jayeh
+1. Toyota even says you can do it in the owners manual.
Other cars, chrysler for example, don't allow you to necessarily choose gears directly. You can only changes modes for the AT, for example D is regular operation, 3 holds gears longer for better performance, and L keeps it in the lowest gear till near the redline then upshifts. All gears are available in all modes!
Old 05-24-2013, 06:54 PM   #15
47_MasoN_47
I wish I could have gotten a 5 speed in my car :(
Old 05-26-2013, 08:17 PM   #16
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
I have 'developed' the same habit, peewee1, always under 40 mph. Stop signs and stoplights. Won't hurt it at all. Nothing wrong with manually shifting an automatic transmission, we have a choice.
Had a TH125 Auto in an '88 Fiero Formula that I manually shifted all the time - never had a problem with it, sold it at 89, 000 miles.....and that was an 80's GM tranny
yougojay is offline   Reply With Quote
Problem help MickZEL DIY / Maintenance / Service 38 08-01-2011 02:52 PM
Back to school sale Short shifter, Shift Knob, EVERYTHING is on sale! TWM Performance TWM Performance 13 09-29-2009 10:55 AM
TWM Performance weighted shift knobs on sale! TWM Performance TWM Performance 5 06-30-2009 09:58 AM
October sale on TWM Performance shift knobs! TWM Performance TWM Performance 1 10-31-2008 05:01 PM
