Old 05-23-2013, 04:40 PM   #1
RedRide
RedRide's Avatar
Yup your fine any car can handle up to twenty percent overfill without any issues more than that can cause excessive oil pressure and can cause a oil pan gasket or valve cover gasket leak if driven with excessive oil for months
YarisSedan is correct as most cars can handle a bit of overfilling without any ill effects .
A problem can arise if you overfill it so much that the 'bottom" of the crank dips in the oil as it spins causing the oil to foam effecting oil pressure and its ability to protect etc .
If after some high revving and/or prolonged highway driving, etc you do not notice any hint of foam on your dip stick, you are OK . A half quart over is usually just fine.
BTW, this is why some engines call for an odd amount of oil. The spec published for oil amount has been adjusted to allow for some overfilling
Did they increase the oil capacity for 09 Yaris? 2007yariz DIY / Maintenance / Service 8 05-18-2011 09:28 PM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
