#1 | ||
0-60 in slow
So the options I had were to move the link outboard and use a longer bolt for the shock, which makes it longer and still single shear on the same semi thin bolt. Move the arms as you can see above, it makes them go at a extreme angle so the forces are uneven side to side IE you transfer more force to one side over the other under twist. This setup isn't ideal but it helps me get a better understanding of how this kind of bar works over just utilizing the torsion beam alone. I could have milled the aluminum down and used a ball joint to get some extra space, but given the interference and the axle play I didn't want to risk it. The third option is the one I'm planning on doing later, is to get 30 degree arms so they sit parallel to the ground using the bottom link. |
#2 | |
0-60 in slow
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 04:19 AM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
| CtrlAltDefeat - Photo-Scavenger Hunt | CtrlAltDefeat | Photo-Video-Media Gallery | 0 | 03-04-2009 02:14 AM |
