If the system is pressurized you want to bring it to a shop that can collect the Freon (as it is illegal to vent it to the air). Once it is purged, you can disassemble it without issue.
I own a vacuum pump and manifold gauge set, so do my own AC work. With my manifold, I can connect a tank to capture the exiting Freon for proper disposal, if I am working on a pressurized system.
#2 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
#3 | |
![]() Drives: 2007 Yaris S AT Sedan Join Date: Oct 2010
#4 | |
To verify that before disconnecting the tubing, you can remove the cover from the valve on the low pressure line (the larger diameter tubing) and pressing the center of the valve for a split second. If nothing comes out it is empty.
#5 | |
Where is that valve you speak of located? Easy to get to? |
#6 | |
| ACRONYM thread | Shroomster | Off-topic / Other Cars / Everything else Discussions | 45 | 02-15-2025 10:30 PM |
| Electrical System Upgrade Advice | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 03-23-2016 01:15 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Ohm's Law and Setting Amp Gain | _S7V7N_ | In Car Entertainment + Electronics (audio / video / alarm) | 24 | 03-13-2012 09:34 PM |
