Old 05-29-2013, 03:11 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Possible you have a huge vacuum leak somewhere, if you start the car and hold the rpms high will it stay running and then die as soon as you let off on the gas.
Old 05-29-2013, 03:35 PM   #2
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
did you run out of gas?
But really, figure out what failed exactly before you start replacing things. Could be several simple causes.
Walbro pump, fuel rail, pressure regulator/gauge, return line, no more fuel problems.
Haha, I tried to correct the problem for 45mins on the side of the highway haha... and no, I already check that possibility haha
Wide open throttle or not it is diying anyways, the only time I can hold it a very little is when I see gas on my air fuel. But it always stall, and stick hard to the lean side... :P
maxthehax is offline   Reply With Quote
Old 05-29-2013, 04:55 PM   #3
Try the bypass connector for your FIC to see if the injector outputs are bad.
Old 05-29-2013, 07:10 PM   #4
maxthehax
maxthehax's Avatar
I tried, it was in my 45mins tryouts lol :P
I completely removed my plug&play harness, right now it is only the OEM ecm controling the engine. I also removed all power supply for 15mins before restarting the engine to let the ecm refresh... no chances...
Originally Posted by Yoda View Post
what does your boost/vacuum gauge read at idle?
The engine doesnt even idle at all... it stall way before, I cannot get a stable rpm at all.
ACRONYM thread Shroomster Off-topic / Other Cars / Everything else Discussions 45 02-15-2025 10:30 PM
2012 Camry Kal-El Off-topic / Other Cars / Everything else Discussions 26 10-02-2011 09:20 PM
