Are you looking specifically for the connectors for each of the sensors that you listed? If so, I believe that I have all of them on hand.
#2 | |
Others gonna be AEM, so no need for them; -water temp -MAP If I forget some I will post them later! Thats a blast you have it all... What about the metal pins that I need to go into the connectors?? I guess I will need special crimper tool. Thanks! Also, I have a echo, so my TB is a drive by cable. Not the electronics one Last edited by maxthehax; 05-30-2013 at 09:20 PM. |
#3 | |
The TPS connector is different. The Toyota part number for the shell is: 90980-11261 The Idle Air Control connector (what you called the PWM) shell is: 90980-11145 The Crank, Cam, and OCV (VVTI) are the same for the Yaris and Echo.
#4 | |
I am currently working a bit on my yaris engine I have on a stand. I already have most of the connectors with butted wires. So that mean I could buy the piece of wire already crimped to make my connection. That require removing the old wires from each connectors, is that easy to do? |
#5 | |
#6 | |
Injectors COils VVTI Crank position Cam position Knock sensor And those I need a new plastic connector plus the wiring; TPS Idle air control If I bring all the connectors I have to my toyota dealer, do you think they have the tools to remove all the pins? They should also be able to order new pins... Thanks! |
#7 | |
The service techs should have the SSTs for popping the various pins. With the number you would need to pop you would probably end up with an hour or two charge. They can order the new pins (for about $15 each), and they will each come with a piece of wire attached. You can only get the actual crimpable pins directly from the manufacturer(s) and my experience with Sumitomo is that you have to buy a minimum of 20,000 of each type of pin.
| The Nitrous Thread | ChinoCharles | Performance Modifications | 116 | 02-16-2016 03:07 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Engine noise and Oil Lamp on | bieniman | DIY / Maintenance / Service | 21 | 12-12-2010 11:47 PM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
| YARIS Wiring Harness for Sale | Lowfront | Items for Sale by private party | 13 | 10-11-2006 03:02 PM |
