Old 05-30-2013, 09:26 PM   #1
maxthehax
maxthehax's Avatar
Drives: Echo HB Turbo 6Speed
What I have are the actual OEM Yaris connectors with the OEM wires (so you would need to solder those wires to you EMS harness. The connector shells would run you about $10 each from Toyota and even they would supply the pins with a piece of wire already attached (for about $15 per pin). The reason for them being pre-crimped is that each pin type requires a completely different crimper (which are about $200 each from Sumitomo).
The TPS connector is different. The Toyota part number for the shell is: 90980-11261
The Idle Air Control connector (what you called the PWM) shell is: 90980-11145
The Crank, Cam, and OCV (VVTI) are the same for the Yaris and Echo.
Cool thanks, I understand now what the toyota guy showed me (little wires already crimped)
I am currently working a bit on my yaris engine I have on a stand. I already have most of the connectors with butted wires. So that mean I could buy the piece of wire already crimped to make my connection. That require removing the old wires from each connectors, is that easy to do?
maxthehax is offline   Reply With Quote
Old 05-30-2013, 09:56 PM   #2
Some of the pins are easy to remove and some are a real pain without a special pin extraction tool for that particular pin type.
Old 05-31-2013, 06:31 PM   #3
maxthehax
maxthehax's Avatar
Damn, here is the list of the connectors that I have and I need to remove pins and put new ones with new wires;
Injectors
COils
VVTI
Crank position
Cam position
Knock sensor
And those I need a new plastic connector plus the wiring;
TPS
Idle air control
If I bring all the connectors I have to my toyota dealer, do you think they have the tools to remove all the pins? They should also be able to order new pins...
Thanks!
Old 05-31-2013, 07:05 PM   #4
Injectors
COils
VVTI
Crank position
Cam position
Knock sensor
TPS
Idle air control
Thanks!
The service techs should have the SSTs for popping the various pins. With the number you would need to pop you would probably end up with an hour or two charge.
They can order the new pins (for about $15 each), and they will each come with a piece of wire attached. You can only get the actual crimpable pins directly from the manufacturer(s) and my experience with Sumitomo is that you have to buy a minimum of 20,000 of each type of pin.
Old 06-01-2013, 06:47 AM   #5
maxthehax
maxthehax's Avatar
cool thanks. I would simply buy already crimped wires from toyota and make a quality solder to my harness.
I thank you very much for all informations. I should update the thread whenever I have news about this, and probably add pictures :P
Old 06-01-2013, 07:28 AM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
This. And there may be a 16-32 week lead time. And they will also probably tell you that those part numbers don't exist (if they're proprietary OEM).
Old 06-01-2013, 07:48 AM   #7
With Sumitomo I had to have a company tax ID to order them. The quoted lead time was 16-32 weeks, but they ended up getting them to me in less than 4 weeks.
Old 06-01-2013, 09:59 AM   #8
maxthehax
maxthehax's Avatar
I don't want all that hassle, I will simply buy the pre-crimped wires from Toyota anyways...
By the way, for soldering my harness, I have 2 type of solder wire at home. Which one is better?
1. Dura pure 95% Tin 5% Antimony
2. Rosin Core 60% Tin 40% Lead
Thanks
Old 06-01-2013, 06:54 PM   #9
CrankyOldMan
That's always a bonus. In our engineering department, we have to beg/plead/steal to get enough of them to do the development testing of our shifters (assuming that we lost our minds and went with a new connector) and normally end up behind schedule as a result of someone not anticipating the lead time.
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Engine noise and Oil Lamp on bieniman DIY / Maintenance / Service 21 12-12-2010 11:47 PM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
YARIS Wiring Harness for Sale Lowfront Items for Sale by private party 13 10-11-2006 03:02 PM
