Old 06-06-2013, 06:59 AM   #1
Originally Posted by tyrone_yaris View Post
So is there a need to open up the pan or its not necessary as the gaskets are not freely available here. Do the magnets get dirty as such which would require cleaning?
I wouldn't drop the pan just to clean the magnets, if the gasket is not easy to come by. They can hold quite a bit of shavings.
Old 06-06-2013, 07:04 AM   #2
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
That's good to hear CT Scott. Since I'm doing a flush at 50,000 km and the next will be done at 100,000 km so just wanna make sure that a simple drain refill will be fine and wanted your input as our conditions here are hot and dusty.
tyrone_yaris is offline   Reply With Quote
Old 06-06-2013, 07:42 AM   #3
tyrone_yaris
CT Scott can you help identify this port
While we're on the subject of the CVT flush for the VItz (K410) transmission, I'm attaching a pic of the port that many have used to refill the CVT fluid. Can you identify this port?
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
