Old 06-06-2013, 09:08 AM   #1
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
It is under the oval shaped black metal piece in the left picture.
You mean that is the CVT filler port for the IKR FE and not the big bolt that is mentioned in the Micromanage link given below??
http://www.microimageonline.com/foru...T-Fluid-Change
tyrone_yaris is offline   Reply With Quote
Old 06-06-2013, 02:09 PM   #2
tyrone_yaris
CTScott would appreciate if you could clarify th above with regard to the filler port mentioned in the Micromanage article. Thanks.
Old 06-06-2013, 02:45 PM   #3
I think it depends on the vintage of the CVT, and perhaps which vehicle it is used on as to if the fill port looks like the one above or the one in my DIY on MI.
Old 06-07-2013, 01:22 AM   #4
tyrone_yaris
Ok so which fill port shld I use in my case, the black oval one or the one in your DIY at MI which I believe is the side bolt marked TC. (Pic attached)
Details of my car: Toyota Belta Year: 2007
1KRFE Engine, Chassis KSP92-BEXNK, CVFC ATM STEPLESS FLOOR SHIFT
Would appreciate if you could clear this confusion as it would help many out here in our country.
Thanks
Tyrone
Old 06-07-2013, 08:08 AM   #5
Thanks
Tyrone
Based on your model code, it would look like the bolt in the picture above, as opposed to the oval black cover.
Old 06-08-2013, 12:52 AM   #6
tyrone_yaris
Thanks for your help. I guess the oval black cover is probably used to check the temp or quality of the fluid using a toyota probe.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
