Old 05-29-2013, 05:06 PM   #37
thatbryanguy
Drives: Yaris 3dr hatch
Well now the current issue is something g I need to deal with but at least I can drive it. Right now everytime I go into neutral from mid-high rpms the engine shuts off. Or if I sit idle too long the rpms very slowly keep dropping till about 600 then the engine stalls itself. It's strange but no codes or anything and I just start it back up and go. Every now and then it will rev itself all the way to 3000 rpm out of no where but then drop back down to 1000. Upon initial start up everytime it sputters and fluctuates a lot until I give it gas. It's interesting and will soon become annoying. Any thoughts? Strange settings on my fuel map maybe?
thatbryanguy is offline   Reply With Quote
Old 05-29-2013, 05:33 PM   #38
yariSB86
yariSB86's Avatar
Drives: 07 Bayou Blue Yaris LB
Thats exactly what i'm dealing with. I've ordered an 08 ecu to install and see if that works. I've already checked for vacuum/boost leaks. The car runs fine when i bypass the FIC. New ecu should get here later this week, hopefully. So I can update once its here :)
_______________________________________________
yariSB86 is offline   Reply With Quote
Old 05-29-2013, 09:25 PM   #39
kou
Drives: 08 lb
My car started to do that when I was running a 1zz throttle body, it started maybe 6months after install. I eventually put the stock tb back and never had the problem again. Now I'm boosted so no real need for it anyway.
Old 05-30-2013, 01:34 AM   #40
thatbryanguy
Yea I may go back to the 1nz TB just to see.
@yariSB86, yea I'm running the 08 ECU now and that's the current condition. I've bypassed it now since cranking the starter every stop light isn't something I wanna do...
Old 05-30-2013, 03:28 PM   #41
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Even though this ended up possibly not being the ECU I figured that I would chime in that I have received the flashed 07 ECU from Scott and will be installing it this weekend to see if it resolves my crank sensor issue when my FIC isn't bypassed.
Old 05-30-2013, 06:21 PM   #42
yariSB86
yariSB86's Avatar
Yes totally want to know how that goes.
Old 05-30-2013, 06:25 PM   #43
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
This is why I mentioned "proceed with caution" in the thread recommending the 1ZZ ....
-Type 07 FFL-
My odometer 03/11
Old 05-30-2013, 07:42 PM   #44
thatbryanguy
The 1zz has worked great for a while now but just with this ECU swap its starting to act up :/
Old 06-03-2013, 02:41 PM   #45
thatbryanguy
I think I'm gonna try to send my 07 ECU to Scott, swap it back to that before I go back to the 1nz TB since the 1zz worked great till I swapped the ECU out now it acts up funny all the time even without the FIC plugged in. Update soon.
Old 06-03-2013, 11:24 PM   #46
fnkngrv
fnkngrv's Avatar
As an update I wasn't able to get my ECU swapped out yet. Family obligations along with the weather than came through became stumbling blocks and I don't have use of my garage right now so hopefully in the next couple days I can spare some time from work.
Old 06-04-2013, 02:32 AM   #47
thatbryanguy
Sweet thanks man!
Old 06-06-2013, 12:26 AM   #48
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Has anyone figured out exactly What the culprid behind the engine stalling with the fic plugged in? My yard is an '08 already so safe to say it's not the ecm. I'm running with 1zz injectors and after setting the response time higher to 810 the problem happens almost everyone I stop. If I bring it as low as 486us (default in the setup) it runs better but still stalls. Everything works fine when bypassed. So fustrated!!!!
DKN-YARIS is offline   Reply With Quote
Old 06-06-2013, 08:00 AM   #49
thatbryanguy
Are you running the stock throttle body or the 1zz throttle body?
Old 06-06-2013, 11:24 AM   #50
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Running stock TB.
Old 06-06-2013, 07:09 PM   #51
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
Are you still getting the random misfire codes? I had it come up just once since i've been playing around with the car to figure out this stalling. I erased the code and its yet to come back...
Old 06-06-2013, 07:36 PM   #52
yariSB86
yariSB86's Avatar
I'm running 07 yaris manual transmission with stock ecu, new colder/shorter gapped spark plugs, 1zz fuel injectors, stock throttle body, 93 octane gas and i stall almost every time when i come to neutral if the FIC is plugged in. Only codes i get are, with the FIC plugged in, p0172. With the FIC bypassed i only get p0335.
Old 06-11-2013, 11:37 AM   #53
DKN-YARIS
DKN-YARIS's Avatar
Drives: YARIS HB
I had one of the two CEL threw a few times, i changed the Camshaft position sensor and using the following settings:
AEM FI/C
x300 firmware
*z104 firmware (slave chip)
injector response set to 648us (using 1zz injectors)
*i'm currently trying all slave chip firmware to see which one has less of a harder time while starting the car. with z104 it takes a few tries before the car turns over.
I spent the past week and a bit trying to figure out what was causing the stalling as it only happens when the FI/C is plugged in leading me to believe it had something to do with firmware + settings making the car stall.
Old 06-11-2013, 06:57 PM   #54
yariSB86
yariSB86's Avatar
My F/IC
So here is my setup:
-Stock 07 ECU
-Stock throttle body
-1zz fuel injectors
-NGK iridium, shorter gapped spark plugs
-Zage turbo kit
-stock oil pan, "tapped" the upper oil pan assembly for return
-K&N oil filter, have a sandwich adaptor for oil pressure sensor and oil feed to turbo
-Royal Purple 5w30 synthetic oil
-Custom 2.25" turbo back exhaust
Lastly my FIC setup:
Does anyone see anything that would cause the car to stall out whenever in neutral? Feedback on anything is greatly appreciated also. Thanks everyone.
FS: AEM FIC + Wiring Harness Boomslang djgab101 Items for Sale by private party 18 12-06-2013 04:36 AM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
AEM FIC to replace CamCon cc101 ?? vten Forced Induction Forum 26 08-04-2012 08:38 AM
AEM FIC works perfectly cdydjded Performance Modifications 58 08-03-2009 07:20 AM
