Old 06-06-2013, 03:09 PM   #19
tyrone_yaris
Drives: Toyota Vitz 2007 facelift
CTScott would appreciate if you could clarify th above with regard to the filler port mentioned in the Micromanage article. Thanks.
tyrone_yaris is offline   Reply With Quote
Old 06-06-2013, 03:45 PM   #20
Originally Posted by tyrone_yaris View Post
You mean that is the CVT filler port for the IKR FE and not the big bolt that is mentioned in the Micromanage link given below??
http://www.microimageonline.com/foru...T-Fluid-Change
I think it depends on the vintage of the CVT, and perhaps which vehicle it is used on as to if the fill port looks like the one above or the one in my DIY on MI.
Old 06-07-2013, 02:22 AM   #21
tyrone_yaris
Ok so which fill port shld I use in my case, the black oval one or the one in your DIY at MI which I believe is the side bolt marked TC. (Pic attached)
Details of my car: Toyota Belta Year: 2007
1KRFE Engine, Chassis KSP92-BEXNK, CVFC ATM STEPLESS FLOOR SHIFT
Would appreciate if you could clear this confusion as it would help many out here in our country.
Thanks
Tyrone
Old 06-07-2013, 09:08 AM   #22
Thanks
Tyrone
Based on your model code, it would look like the bolt in the picture above, as opposed to the oval black cover.
Old 06-08-2013, 01:52 AM   #23
tyrone_yaris
Thanks for your help. I guess the oval black cover is probably used to check the temp or quality of the fluid using a toyota probe.
Old 06-08-2013, 07:57 AM   #24
ciscobear
Drives: Toyota Belta
Look what I found Tyrone. This guy changing his fluid on his Estima. Can anyone read the Japanese in the did?
http://www.youtube.com/watch?v=uWF7m7oQ7QE
I gotta post this for murtaza.
ciscobear is offline   Reply With Quote
Old 06-08-2013, 08:14 AM   #25
tyrone_yaris
That's Coool!!!! Is it the same K410 as the Vitz / Belta here ?
Old 06-08-2013, 12:46 PM   #26
ciscobear
Seems to be K112 for the Estima. But seems to be same shape, outer body. I figure the internals maybe different.
Old 06-08-2013, 06:39 PM   #27
VitzHead
Drives: 2009 Vitz 1.5 RS
Well I've got a 09' Vitz RS with a CVT, 7-speed with paddle shifters and CVT-Sport mode.
It's a hoot to drive as it kinda feels like i'm driving a 'Baby' sports car or sumthin. LOL
I didn't get a owners manual with the car which I suspect would've been in Japanese anyway, but I was curious about the CVT so I looked around the engine bay & noticed there isn't a transmission dip-stick (like conventional automatics).
A friend who's a mechanic told me that the CVT fluid is good for the lifetime of the car, I kinda find this hard to believe .... Is this true???
VitzHead is offline   Reply With Quote
Old 06-08-2013, 11:08 PM   #28
ciscobear
Nope that lifetime talk is nonsense. Watch this http://www.youtube.com/watch?v=037cAvY5y3Q
Old 06-12-2013, 08:07 AM   #29
tyrone_yaris
Hi CT Scott. Thanks for all your help. I just managed to get the CVT fluid drained and refilled today, as detailed by you in Micro Image and with your advice here on the forum.
Thanks once again.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 02:11 AM
