Old 06-07-2013, 11:57 PM   #1
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
there was a guy a while back that did an electric supercharger in a way that was viable (thomas knight) though he has kind of fallen into obscurity. his kits were like $2500 and came with no management. he used a bank of batteries in the trunk that had to be recharged so it was almost like nitrous as in you had a difinitive time before refueling the system.
his also had a constant CFM so the boost would go down as the RPMs went up. his dyno graphs were almost flat. you would get boost and go to a certain hp and just stay there to redline but the PSI would drop as the RPMs would rise.
All that is really old though and I haven't read anything about it in a while. The separate power supply I think is the key and the blower with a huge CFM with the capability of holding a high enough PSI. Even then, it is limited by charge of external batteries.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Fan Not Spinning Up, Random Airbag Light drannonb DIY / Maintenance / Service 12 10-23-2012 03:33 PM
Engine fan on when standing still and low mpg 2002 yaris andqe DIY / Maintenance / Service 5 09-15-2012 03:32 PM
AC Blower Motor / Fan Does Not Turn on Period dyslexicanaboko DIY / Maintenance / Service 7 01-30-2012 10:59 PM
Abnormal radiator fan hi577 DIY / Maintenance / Service 0 01-21-2012 03:34 AM
Radiator Fan Rattle? Betrivent DIY / Maintenance / Service 9 06-23-2011 03:56 AM
