![]() ![]() Drives: 07 Yaris 3DR Join Date: Apr 2007
Thanks for your input.
I'm fairly sure its not the thermostat or the temperature sensor because when I went to start the car later on after it had an hour or more to cool down the light that shows the coolant temperature is low was on, as it always is when I start the car for the first time of the day or whatever. Unless its a different sensor for the low than it is for the high but I don't see why that would be the case. My friend said I should start the car with the cap off of the radiator to see if the coolant is bubbling. He said if it is then there is a leak somewhere and air is getting into the system and I may need to get a new radiator installed. I've never heard of this test before. Is that true? |
#2 | |
Yes. starting the car with the cap off and watching for bubbling will tell you if there is air in the system. If you have a leak, you will be losing fluid, so when you remove the cap, you will need to add fluid.
| battery light stays on but running fine | galactus | Mid-Atlantic | 13 | 08-15-2013 09:50 AM |
| Check Engine and Traction Control Light On | limey163 | DIY / Maintenance / Service | 21 | 07-14-2013 03:03 PM |
| Cold air intake....check engine light on...??? | JohnnyMalice | Performance Modifications | 4 | 04-29-2012 09:46 PM |
| check engine light - reading codes? | delbo21 | DIY / Maintenance / Service | 3 | 09-02-2011 05:48 AM |
| Engine management light for 300 miles then off for 300 - this cycle keeps repeating | stripey | DIY / Maintenance / Service | 0 | 08-01-2010 05:43 PM |
