Old 06-10-2013, 08:41 AM   #1
yougojay
25, 550 MILES!
Drives: Yaris L Coupe
Originally Posted by AbsolutelyRed View Post
I looked underneath and everything seems ok but I'm not sure if I have done a thorough enough inspection.
My best suggestion is to take a good look at the configuration on one side and compare it to the other. The passenger side set-up underneath the seat is probably very similar to the drivers side.
Upon close inspection you will most likely find something amiss...you may have disconnected a guide wire or whatnot while vacuuming, or if there was someone sitting in the backseat behind you, may have dislodged something with their foot.
Take a close look at both sides and compare them, you will find something different I am sure. You will find what's wrong!
yougojay is offline   Reply With Quote
2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. trini_per4mance General Yaris / Vitz Discussion 100 06-08-2022 09:54 PM
good to know ; 2008 YARIS 127,000 + miles ... Hershey General Yaris / Vitz Discussion 2 02-24-2010 11:08 PM
2008 Scion tC part-out MiniTRD Items for Sale by private party 3 08-27-2009 03:05 AM
When did you experience your first mechanical failure? How serious was it? twowheels General Yaris / Vitz Discussion 40 08-21-2009 02:38 PM
