Old 06-11-2013, 01:59 PM   #1
Geoff Peace
Drives: Yaris 1.33 litre 2011
Originally Posted by Eren_13 View Post
Hi Geoff
I've changed both the interior map reading lights and dome. Both of which I just pried on the plastic bits and they eventually do pop off. Can get you reference photos of where I pulled if you wish? Are you changing the centre lights or the ones above driver and passenger?
Eren.
Thankyou for your reply Eren. It is the centre light bulb I need to change, the ones over the passenger/driver, vanity lights I think they are called are OK. Photographs would be an enormous help, I am very wary of plastic parts and simply do not wish to break anything. Once again, thankyou for your help.
Regards Geoff Peace.
Geoff Peace is offline   Reply With Quote
Old 06-12-2013, 08:07 AM   #2
Eren_13
Eren_13's Avatar
Drives: Yaris SR '12
You're very welcome. The centre lights I literally just pulled at the sides of the plastic cover and off it popped. Seeing as there was no help in the manual I did in fact take a risk as I wasn't sure if the whole unit would come out. I'll try and upload some photos this evening Geoff and hopefully they'll help. I don't want to suggest pulling in case it does go the opposite way for you and then it breaks but that's what I did so if you feel up to it then give it a go.
The forever growing to do / to buy list:
FIX Projectors - FINALLY DONE!
XB LED fogs - Done
Lowering springs - Done
MOMO Revenge Evo X - Currently selling body parts for
Declare bankruptcy - Done
Eren_13 is offline   Reply With Quote
Old 06-12-2013, 12:50 PM   #3
Geoff Peace
Thankyou for your help Erren, I will wait for your photographs before I try. Just to be on the safe side!
Old 06-16-2013, 01:06 PM   #4
Geoff Peace
Eren 13. I wonder if you would be so kind as to post a photograph or two showing how to remove the interior light on the Mk.3 Yaris. I have tried pulling and prising but the thing does not want to cooperate. I notice there is now another thread on the same subject on the forum. If you can spare the time I would be most grateful.
Bulb Replacement Guide (led Sizes) theFEVA Cosmetic Modifications (Exterior/Interior) 113 02-28-2017 12:02 PM
2000 1.3 YARIS Wing panel replacement jjosull DIY / Maintenance / Service 1 02-12-2013 01:53 PM
