2ZR swap. DO IT! Ask how!
I woke up this morning thinking about how this would work, and I think it may be slightly too big. I measured the neck of the Blitz at some point, but I've forgotten the exact dimension. I'm thinking 54mm O.D., but that seems awful small if the I.D. is 52mm. I'll have to take the calipers out to the car and measure it again.
#2 | |
play every day
The bore diameter of the Blitz intake should be at least 46mm to fit the 1NZ throttle body. So there would need to be a perimeter transition of 4.5mm, or slightly less than 3/16 of an inch. That's how much the Blitz runner would need to be flared out at the end. It would leave a thin outer edge which would slip fit up inside the tapered bellmouth curve. It would then be needed to be welded from the outside. If less than 2 inches were cut off of the Blitz runner, the adaptor would make up that difference, and the 1ZZ throttle body would end up in the same place as the 1NZ. |
| BLITZ supercharger kits IN STOCK | cali yaris | Micro Image | 34 | 06-02-2012 10:31 AM |
| FS: blitz supercharger kit + camcon | vten | Items for Sale by private party | 20 | 02-22-2012 09:12 AM |
| Blitz supercharger and everything else. 56K beware | camelll | Items for Sale by private party | 23 | 05-06-2011 09:32 AM |
| gap for spark plugs for the blitz supercharger? | whooppee777 | Forced Induction Forum | 2 | 03-12-2011 01:09 PM |
