![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
removing wheel hub
rear hub 07 hatch
I beat on these rear hubs with a wood mallet for a long time and there was NO sign of them coming off or even loosening. Do I need a special tool to get the hubs off??? Are the front ones the same also?? I meant the brake drum...not the inner hub...its the drum thats stuck. Last edited by yaris9876; 06-12-2013 at 03:36 PM. |
If you are trying to take the drum off you will need 2 bolts that thread into the 2 holes on the front off the drum. Screw in the bolts evenly and they will push the drum off.
I think the bolt size you need is M8x1.25 but I am not positive.
crappy video but will give you an idea.
http://www.youtube.com/watch?v=JFLP18_fNBg |
I honestly dont rememeber seeing holes in the drum.....I guess I have to take off the wheels again??
I didnt see them. |
Here's a picture of the location of the threaded holes. Also, make sure the ebrake is off, or you will never get the drums off.
that helps....
btw is there a good pictorial of doing the front wheel bearings, not a video,just a good tutorial from someone who has done it..?? |
can you describe this clip process better or link to better pics??
http://www.popularmechanics.com/cars...enance/1782947 |
#9 | |
Question: are you going to buy a new wheel bearing / hub assembly, or just a wheel bearing? I've been told to do the hub assembly as a unit. I didn't have that much at the time I did it, so I only did the wheel bearing. I will TRY and get something going tonight. edit: yikes. removing the pics from my windows phone isn't as easy as it was with my iPhone. damn it. Last edited by justjesus; 06-18-2013 at 07:42 PM. |
I am doing the whole hub///do you know the bolt torque on the hub bolts?? hope you get the pics up
it would help.. |
the hub isn't bolted to the spindle assembly. It's pressed on. For that part, I took it to a shop (Pep Boys). - If you're talking about the lugs, those too are pressed on (and should be part of the hub assembly you buy new)
I brought a blank CD to help me move the files off my phone and onto the internet. I'll be doing it little by little during the day |
the rear hub assembly is bolted on to the rear axle. There are 4 bolts and I am looking at them right now. Anyone know the torque..???
67 ft lbs for the four bolts
![]() ![]() ![]() Drives: 2010 Yaris HB Blazin' Blue Join Date: Feb 2011
Like others have said, buy the whole hub assembly, it's way easier unless you own or have access to a press. Here is an example of a new Yaris hub from Rock Auto, where I buy about 80% of my parts.....
http://www.rockauto.com/catalog/more...658&cc=1444575 This is what you end up with if you break them down yourself, hubs and bearing carriers just waiting for bearings and seals to be pressed back in..... http://smg.photobucket.com/user/race...tml?sort=6&o=9 And this is what you'll need to make it all happen, but really there's more to it than that, this is just a simplified look at what's involved...... http://smg.photobucket.com/user/race...ml?sort=2&o=38 racerb
racerb '86 Celica GT '87 Celica GT-S '98 Rav4L '01 Tundra SR5 |
I got the whole assembly today... same as the pic but mine were Timken and look good. I dont have a torque wrench, is 67 pounds reachable with a regular open end wrench???
can someone verify that the hub screw holes are M8 1.25 ????
I got into it only to realize I didnt have a 14 mm.I was going to buy one and then I called a Les Schwab
and they said 90$ if I had the parts. So they did it . It took 3 hours by an experienced brake mechanic who needed an air chisel to get the hubs off. I would not have gotten 1/4 of the way thru it. Glad I hired someone else. Last edited by yaris9876; 06-25-2013 at 10:02 PM. |
| Installing Rear Wheel Bearing Hub | brad4ds | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 07-22-2011 06:34 PM |
| FS: Sparco Steering Wheel Hub Adapter for Scion XA/XB &Toyota's | jookybanana | Items for Sale by private party | 0 | 07-21-2011 05:38 PM |
| Steering wheel hub adapter | spdfrk | Cosmetic Modifications (Exterior/Interior) | 7 | 02-18-2011 04:44 PM |
| anyone knows if wheel spacer can be placed behind the hub??? | jackrabbit | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-02-2010 06:41 PM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
