Old 06-23-2013, 09:10 AM   #1
ciscobear
Drives: Toyota Belta
Plugs were changed to correct spec, starting motor cleaned up and lubed, gas tank filter was cleaned. No diagnostic codes revealed. Additional grounds were added, battery changed last year. Still the problem persists especially on a colder morning, keep in mind however our ambient temps are around 28 degrees Celsius. Throttle body was cleaned as well.
ciscobear is offline   Reply With Quote
Old 03-07-2015, 12:39 PM   #2
floringvrl
Drives: yaris
The same problem i have at my 2007 Yaris with the same engine, and it doesnt matter if the engine is cold or hot. How do you fixed the problem?
thak you
floringvrl is offline   Reply With Quote
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 02:47 PM
2002 diesel, problem starting when engine is hot casadelaloma DIY / Maintenance / Service 0 10-18-2010 08:48 AM
Weird starting issue 2007 auto yaris Nask26 DIY / Maintenance / Service 11 07-28-2010 12:29 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
