When you did the jumping of the pins on the OBD port, were you able to see the ABS light flash to indicate the DTC?
If so, and the error indicates the sensor on the wheel where you changed the bearing, you may have damaged the sensor in the process of changing it, and that is why you can't clear the DTC.
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| HELP! ABS & BRAKE LIGHT ON SIMULTANEOUSLY! | mizhgolightly | DIY / Maintenance / Service | 45 | 05-03-2022 02:59 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| Reverse light vs Rear Fog light | cooldavidko | General Yaris / Vitz Discussion | 3 | 01-03-2007 03:09 AM |
