![]() Drives: Yaris HB 2007 Join Date: Jun 2013
So I got my ac looked at again. The shop hooked it up to an ac machine and it worked once. Next they replaced the expansion valve. That didn't do anything. They checked a lot of the electrical stuff but to no avail. They are pointing to ac compressor now. The above posts claim that there is no relay for the ac compressor but I was looking on rock auto and there is one for it under relays....
no a/c + traffic =
#2 | |
With them saying the compressor is bad, do they think the clutch is not pulling in, or is it pulling in, but the compressor does not create pressure? You can do a quick test of the compressor by applying 12V to the green wire of the compressor. I would not run it for long that way, but in 30 seconds you should be able to see if it then generates cold air. If it does, then I would say that the AC ECU is bad.
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| 3 Drive Throttle Contoller by NTD | Sabretooth | Performance Modifications | 31 | 10-07-2010 12:12 PM |
| 2006 Yaris Hatchback Replacing Stereo Head Unit help | lauren24 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-01-2010 11:13 PM |
| Req: Head unit suggestions. | xed | In Car Entertainment + Electronics (audio / video / alarm) | 21 | 08-09-2007 07:38 PM |
