ヤリスワールド
Drives: 2008 HB Join Date: May 2010
2008 yaris ,automatic.,60,000
All this came on very fast ! car was running great then started odd sluggish shifting and then downhill fast on multi problems ! very odd ! Threw a po335 code so changed the crank sensor ,no change in problem & code returned. Problems... brake applied car dies, put in gear car dies,dash lights blink too- sometimes, power steering assist is cutting off & on too, very odd shifting issues,clunkling etc. any clue ? |
ヤリスワールド
ok to add to the weirdness ! I was thinking short of some type due to the dash lights turning off when brake applied & dash going totally out when heater turned up and killing car sometimes.
So I started lookinh over wires etc and removeing anything I had installed ,well that led to the ultraguage so I unplugged it & it killed car right away ??? then it gets really weird a few lights on dash stay on like oil light when cars off & keys out of ignition ??? Then the heater fan starts runnning ?? so I think well one more reset by removeing negative batt cable wont hurt. So i un hook cable and when re hooking it up a larger than normal spark happens ( i know this happens sometimes & normally thier is a tiny spark on resttachment) well i go back restart car and it semms fine WTF ? RE PLUG IN ultra guage and it all working again ?? I dont get it ? |
The large spark on reconnecting the battery indicates that something is drawing significant current. The dash lights staying on with the ignition off sounds like a relay's contacts are staying closed when they should not be.
Do you per chance have an aftermarket keyless entry, remote starter, or alarm?
#4 | |
ヤリスワールド
no recent mods of any type, has a amp ,fogs ,ultra guage thats about it for items i installed thats electrical ? Strange that it went from shifting odd,to the po335 code , to major electric issues all in 2 days .man car has been great till yesterday ? |
#5 | |
ヤリスワールド
Your the man on this stuff , I am going through it all
Per your guide . Thank you ! |
ヤリスワールド
Your a god ! The st relay was causing the starter issue & maybe more. Should I replace relay ? Pal says once their bad it can happen again ? Also do you think that the st being stuck could have caused so much electrical chaos ? Car seems to be fine now , I think the crank sensor caused the initial issues with shifting and some how in all this the st relay got stuck & really caused problems . Thanks for all the help ,it was truly a correct direction !!
#8 | |
| 2009 Yaris starting issue -need help | cudchew | DIY / Maintenance / Service | 15 | 12-16-2011 02:24 AM |
| 2007 Yaris Door Lock Issue | bhola | General Yaris / Vitz Discussion | 7 | 10-05-2010 12:01 AM |
